Previous in Forum: Calculation for Stretch of Screw   Next in Forum: Amonia Leakage Testing Method or SOP
Installation of Screw Roofing
03/11/2011 2:09 AM
What is the best equipment to install screw roofing, lets say on a 10m height location. I mean what are the tools to use.
=D
Re: Installation of Screw Roofing
03/11/2011 8:23 AM
What exactly do you mean by "Screw Roofing"?
Do you mean corrugated roofing? If so then you need a screw gun (that's like a drill with a screw adapter), a good saw, a tape measurer and a whole lot of screws. There will be some other things you'll need as well. A ladder, marker or pencil...
CARPE CRUSTULORUM!
03/12/2011 1:10 AM
You forgot to mention that the best bit about the materials you suggested is that they can be used not only on roofs at 10 meter heights, but at 4 and 7 meter as well. How's that for versatile tools? PS, maybe you should have included a safety harness in the list.
03/12/2011 1:31 AM
I pre-drill my screw holes to line up with the purlins. Make a stack of the panels and drill them all at once. If you use a screw gun you can set the torque so that the washers are not squished out... Also with pre-drilled holes, it looks like you knew what you were doing...
Johannes
Register to Reply 3 comments
Johannescnc (1); not so smart (1); Olebogile (1)
