One approach is to use air pressure and use a piston to compress the pouch between two metal plates. A low amount such as 15 psi might be adequate but this becomes trial and error. Initially, place your oil pouch within a larger bag so that you contain the oil when the pouch breaks. You will then learn what the right amount of pressure is for an ongoing, non-destructive test.
