Previous in Forum: Oil Pouches Leakage Testing SOP   Next in Forum: Blue Print Tolerance Block
Surface and Subsurface Cracks, Chips in 31803 Grade
03/23/2011 4:55 AM
Dear sir ,
we have a EAF root of stainless steel making route from scrap 40Tons per heat. WE have prepared some heats of 31803 grade with standerd chemistry. We prepare 240X280 billets and then roll it to 125Ø dia. We Solution anneal it to 1060°C for 4 Hrs. After that we peel it to 121Ø bright bar in 2 stages. The Bars are showing continous problems of 4 types of defects. 1. Straight cracks of around 10 -20 mm dia at some locations on bars. 2. a networks of cracks which are not much straight which shows oxides after EDAX analysis. 3. Chips 4.Black patches.
We are getting around 60% bars to be full lenght ok.
To take care of black patches we have increased the rolling size upto 127Ø and peeling nw is done in 3 steps.
But we are not sure about reson for the different crack which we are not able to remove even after peeling 4 - 5 mm.
Can anyone help me regarding this ??
Can u please tell me about what are the metallurgical factors responsible for formation of cracks, chips and other surface defects in steels
Love is like a butterfly, it settles upon you when you least expect it
Pathfinder Tags: metallurgical problem
Re: Surface and Subsurface Cracks, Chips in 31803 Grade
03/24/2011 9:30 AM
This may be way off point. But I worked at a steel mill years ago as a young man. They were bottom pouring ingots to be cut for train axles. I ran the torch system that cut the ingots. I noted when the pour started and when it ended, this I done for myself. I found out that if the pour was under 30 minutes that half of the pour would be scrap because of holes and cracks. Once that was determined by engineers they put a pour time system in place and we never had the cracks again.
Your problem may be completely different, but time or the lack of time in the pour caused our problem further done product line.
Hope this helps.
03/25/2011 6:23 AM
Dear Alfarata,
Thanks for ur reply. But our problem is a bit different.
Register to Reply 2 comments
You might be interested in: Amplifier and Comparator Chips, Memory Chips, CPU Chips
