Previous in Forum: Swingarm Roll Center   Next in Forum: 2004 H2-Hummer
EBS Codes
03/12/2011 9:22 AM
I have a 2004 Impala LS with a 3800 engine and i have 2 ABS codes,C1247 and C1214. What do these codes refer to ? THANKS
Re: EBS Codes
03/12/2011 11:26 AM
C1214 System relay contact or coil circuit open
C1247 Low brake fluid detected
You're welcome.
Re: EBS Codes
03/12/2011 1:52 PM
DTC C1214 Brake Control Relay Contact Circuit Open
DTC C1247 Left Front ABS Motor Free Spins
The low break fluid was prior to the traction control/ abs combination
Jim
Re: EBS Codes
03/12/2011 1:56 PM
Thanks for the correction. I think you know more about this than I do.
Re: EBS Codes
03/12/2011 2:15 PM
the low brake fluid light came on several weeks ago so i added some fluid and the light went off. after replacing the pads and pushing the pistons back the fluid was up to the full mark. this time the low brake fluid light came on after going thru a drive thru car wash. i disconnected the wire to the fluid sensor in the M/C reservoir and the lights went out. i replace the sensor in the M/C reservoir but the light came back on till i disconnected it again. the car stops well and the brakes seem fine
Good Answers: 123
Re: EBS Codes
03/12/2011 10:40 PM
The fluid level sensor is pretty simple in design. Try removing it from the master, and cleaning it and re-installing it. If that does not solve the issue, I would try a junk yard. They should be used on many of the GM cars. Good luck.
Bob
Re: EBS Codes
03/13/2011 1:07 AM
THANKS i will give it a try
Register to Reply 6 comments
bob c (1); Jspeop (1); lyn (2); motorman (2)
