Previous in Forum: Linglong Tyres   Next in Forum: C240 02
ECT 2003 Cavalier
03/14/2011 8:37 PM
can you all tell where this sensor is better than 'under the radiator hose between the motor and the radiator'? a picture would be super sweet almost diabetic thanks brothers
MattJohnson
Re: ect 2003 cavalier
03/14/2011 8:54 PM
Get involved, you'll understand.
Where have you looked so far??
Re: ECT 2003 Cavalier
03/15/2011 12:04 AM
I don't have a picture but it will be located in the thermostat housing. If you follow the upper hose from the radiator it will be at the opposite end from the radiator.
Jim
Good Answers: 97
03/15/2011 5:27 AM
No library there, check for car manual at the library and sometimes a picture is found in them specific to your car.
03/15/2011 11:18 AM
Like Jspeop said. Follow the upper radiator hose from the radiator to the thermostat housing that is where it is located on the thermostat housing. The thermostat housing is the part between that end of the hose and the engine where the hose connects.
“If you forget you have to struggle for improvement you go backward.”
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
03/16/2011 7:03 AM
I'm no auto DIY, but there's some discussion here mentioning a Cav sensor.
here's a pic from that forum.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
03/20/2011 9:44 PM
i would like to thank eveyone for theyre help the sensor is on the back of the motor on the rhs. wouldnt you know its a real boogger to get out :)
MattJohnson
Register to Reply 6 comments
bwire (1); Jspeop (1); langyaw (1); lyn (1); MattJohnson (1); mrclean (1)
You might be interested in: Air Hose and Air Duct Hose, Hose Crimpers, Hose Reels
