Previous in Forum: ECT 2003 Cavalier   Next in Forum: Water Content in Diesel Fuel
9 comments
C240 02
03/14/2011 9:42 PM
Hello, my car runs ruff in the morning when I start it. It had been sitting for 2 days, while driving the car it just shut-off and the Engine light came on.... I waited for about 20mins it started and I drove it to the shop.. My spark plugs were change at 100,000 but not the wires,,,,I am hoping its the wires or somehting not over 2,000....Dose anyone have any idea on whats going on with my car?
Thank You
Re: C240 02
03/15/2011 12:15 AM
If you could get the dtc that is stored when the engine light came on it would give us all more information to be able to make n educated guess since e are diagnosing at long distance. The members here have a lot of knowledge stored in their minds but we can't use it if we have no input to allow us to use that knowledge. Its like asking some I have a flat tire and expecting us to tell you which position the flat one is in. So give us something to work with and we will attempt to help.
Jim
Re: C240 02
03/16/2011 12:31 AM
Hi Jim whats the DTC, I didnt see any msg like that. I am thinking it the wires they have not been changed and I have over 133,000, they did the spark plugs but not the wires....
Thanks
Re: C240 02
03/18/2011 3:32 AM
Its was a crank sensor...all is well.
Thanks Jim
Have a great Weekend!
Re: C240 02
03/15/2011 6:51 AM
Have the shop check the ignition module if it has one. It should be in or around the distributor. These like to go bad.
Re: C240 02
03/15/2011 11:55 PM
What make & model? Does it smoke when you first crank it?
Re: C240 02
03/16/2011 1:42 AM
DTC stands for diagnostic trouble code and to pull them you need to have it plugged into a OBD2 scanner. Most auto part stores will plug in and read the codes and give them to you. where they come from is the onboard computer monitors a multitude of sensors in the vehicle and if they give readings outside of the allowable range then it will store a code in the computer which allows a technician to progress through a diagnostic tree of test and will guide you to the faulty system. It sounds extremely complex but if there are more than one code stored then a good tech can usually determine the problem from experience and knowledge of how all of the systems talk to each other.
Jim
Re: C240 02
03/16/2011 2:38 PM
I am going to bet that either you are out of gas or the crankshaft position sensor is bad.
Good Answers: 123
Re: C240 02
03/17/2011 2:22 PM
Mechanic A says it could be the ignition module. Mechanic B says it could be out of gasoline. Mechanic Bob C says that it could be time to drink my self stupid.
Bob
Re: C240 02
03/17/2011 4:51 PM
Bob I'll drink some of that stupid juice to.
Jim
Register to Reply 9 comments
bob c (1); h2om (1); Jspeop (3); kramarat (1); mikko99 (2); oem (1)
You might be interested in: Power Plugs, Plugs, Stoppers and Inserts, Bus Plugs
