Previous in Forum: Making Fiberglass Flares   Next in Forum: The Future of Driver Controls
Parallel Entry Principle
04/06/2007 8:37 AM
I am trying to get information on roll dynamics and what I believe is called the parallel entry principle. My problem is I have a manufacturing process that uses many different sized drums or rolls that the processed product must travel through in order to become the finished good. I am convinced that any minor change in placement of a new drum when the old drum wears out will cause an upset condition, crease in the processed good, or cause a tension issue. I remember an article on what I believe the author called the parallel entry principle that could back my case for a new piece of alignment gear.
Any help would be appreciated.
Good Answers: 54
Re: Parallel Entry Principle
04/08/2007 10:57 PM
Mr. Guest,
I don't know anything or very little about paper manufacturing but I Googled "parallel entry principle" and got several hits all to one article. That must be the article you're referring to. Have you read it? If you have, I've nothing else to offer. If you haven't, well, here you are: http://www.google.com/search?hl=en&q=%22parallel+entry+principle%22
04/09/2007 9:49 AM
Thank you. You know, I googled the same and found over 140000 references and none of them stuck out like this one. This is exactly the one I was looking for. I need to remember this. Although I am not in paper manufactuing, the principles are the same on web guiding.
Thanks again.
You might be interested in: Drum Pulleys, Entry Gates, Drum Heaters
