Previous in Forum: Tml Location On Seam Pipes And Fittings   Next in Forum: Nozzle Cutout in Rolled Shell of Vessel with Cladding
8 comments
Vibration Analysis
03/19/2011 1:13 PM
Can any one suggest best practice for vibration analysis for slow speed machines i.e. less than 50 RPM.
Also i would be thankful if i find some websites giving proper knowledge for vibration analysis for slow speed machines..
Pathfinder Tags: vibration analysis
Good Answers: 53
Re: Vibration analysis for slow speed machines
03/19/2011 2:15 PM
There are piezoelectric sensors available with built in amplifier, you can Analyze output waveform on a CRO.
04/09/2011 10:58 PM
I would be thankful if someone have some good literature for vibration analysis
04/09/2011 11:11 PM
Have you tried vibration analysis.
03/19/2011 2:44 PM
When you go for slow speed machines, try for the vibration spectrum on amplitude (mm) or at the worst velocity (mm/s).
What are the features you are trying to monitor will largely define what exactly you should attempt.
For our machines usually an FFT suffice to monitor the gears and bearings. However the time series analysis some times provide much more information than the FFT (which averages over a period).
The vibration analysis is a huge subject and going through web may not be enough. Better way is to get hold of consultants/experts which you can hire from universities or other places (eg FAG, SKF etc have their condition monitoring groups who will do the coondition monitoring for you with their equipment and give you the results and they conduct regular classes too for this (of course on chargeable basis)
05/07/2011 11:45 AM
Thanks,
We have purchased ProofTechnik make instrument and measuring Shock pulse measurement.But it is required to normalize the readings taken by the instrument.
For normalizing ,we need to provide shaft dia. and RPM-On this basis software calculates dBi value.But we have to provide dBa value also.
Can anyone guide how dBa value should be feed to get normalized readings.?
03/19/2011 6:47 PM
Many accelerometer chips are designed to specifically work at these low frequencies. You can even get these in three axes orientation that permit use in inertial navigation systems. Before you or anybody else here freaks at some of the prices you'll find for some of these devices, no budget was specified. Similarly no resolution or anticipated energy levels was specified either.
Re: Vibration Analysis
03/20/2011 12:12 PM
If you choose an FFT analyzer (which includes DSP processing, and usually programmability), be sure to use synchronous sampling. Low RPM machines frequently change RPM due to load variations, and synchronous sampling will assure that harmonics are always sampled at integral multiples of the RPM. This will make level measurements relevent for each harmonic.
See the attached URL for more on synchronous sampling:
http://www.wavelet.org/tutorial/synch.htm
08/22/2011 5:19 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Register to Reply 8 comments
Anonymous Poster (1); electricaleng (1); gohiljayesh (2); rakesh_semwal (1); redfred (2); WoodwardDL (1)
