Good day my brilliant friends!
I have a Westward 115v wirefeedwelder (fluxcore). The output was 75 amps but I toasted a diode and decided to upgrade the heat sink and diodes from 50 amp units to 75 amp units with fan cooled oversized finned heat sinks. I have read that voltage spikes can quickly ruin the diodes, and a resistor and diode should be used across the output to absorb any destructive spikes. Can someone kindly give me some specifications on the capacitor and diode I need to use? I believe the voltage output is 30 volts or so dc at 100 amps or less now.
Thank you so much!
