Previous in Forum: Main Reinforcement In Shorter Direction   Next in Forum: 22.5 & 11.25 Degree MJ Bends
10 comments
Lightening Arester
03/20/2011 2:52 AM
What is the maximum capacity or coverage area for a single Lightening Arester? I have to provide 70,000 square meter area under LA. Any latest technology will help me?
N.Vigneshkumar
Pathfinder Tags: Lightening Arester
Re: Lightening arester
03/20/2011 5:44 AM
Are you taking a test, or did you get a new job?
Re: Lightening arrester
03/23/2011 12:07 PM
Its not a test. This is supposed to happened in my current project
N.Vigneshkumar
Good Answers: 53
03/20/2011 6:36 AM
In all cases of lighting those may take place in the specified area (70000 Sq Meter), the distance between lighting and antenna should be significantly lower than of distance between any point/object on ground and lightning, So height of antenna is crucial, My own conman sense thoughts, may not be fully correct,
Its a safety related matter so you should be talking some expert,And also wait for someone with better experience on subject.
Re: Lightening Arrester
03/20/2011 2:14 PM
It depends on the structure's shape, radius of your rolling sphere, lightning protection level and class, the type of lightning protection being used, the standards the system is being designed to, material and cross sectional area of the arrester/down conductors etc, etc, etc.
There is no simple 'space them 10 feet high and 10 feet apart' rule anyone here can quote.
Lightning protection is a very specialised field, I would suggest consulting with a local lightning protection supplier as they may be able to offer (cheap) guidance. Alternatively you will need to either hire a consultant or engineer, or buy all the applicable standards and start reading up.
Jack - Former lightning protection and design engineer.
Re: Lightening Arester
03/20/2011 3:15 PM
Just a caution (and partially quoting a response I originally made to http://cr4.globalspec.com/comment/667868).
I would not trust anyone basing their recommendations or calculations on any of the following:
  • Collection Volume Method (CVM)
  • Eriksson's Model
  • ESE (Early Streamer Emission) lightning rods
  • Dynasphere lightning rods
"Just a general caution: there is a dispute in the IEEE over a new (revised) standard being proposed (and actually, already approved, but now being contested).
"A summary of the allegations against Draft Standard 998 is that the "document has been corrupted by ERICO by including the Collection Volume Method (CVM) / Eriksson's Model, so as to promote the sale of its Dynasphere and other ESE (Early Streamer Emission) lightning rods".
... "My reading of the discussions on the lightningprotection@yahoogroups.com mail list make me very suspicious of the CVM or the ESE lightning rods.
"Also, it seems a pretty sad thing for the IEEE standards effort."
03/20/2011 8:17 PM
As someone involved in the electrical standards approval (and indirectly in the committee goings-on) it is quite common (and irritating) for groups to lobby and try and change the standards to benefit their products to the general detriment of the rest of the standard.
There is always the fall-back "previous version of the standard".
03/22/2011 12:54 AM
Contact an ESE manufacturer or a Consultant
pnaban
03/22/2011 10:07 AM
I recommend strongly against contacting an *ESE* manufacturer or consultant.
See my post #4.
A consultant in the field of lightening who is not affiliated in any way with ESE or ERICO would be a good approach.
03/23/2011 10:59 AM
"lightening"--darn, that's embarrassing!
03/23/2011 9:08 AM
First: .... everyone .......pay attention !!!
If we are going to attempt to conduct this forum in English, lets try to spell better !! Spell checkers, like air are available to everyone !!!
We are all highly educated here, have access to the internet and have grasped even rudimentary English syntax !!
It is not "Lightening Arester" .....the correct spelling is "Lightning Arrester"...also commonly called air terminal
Second: This question about terminal coverage has been asked a bazillion times. The answers are in NFPA 70
Register to Reply 10 comments
Anonymous Poster (1); jack of all trades (2); jai.vignesh (1); lyn (1); pnaban (1); rakesh_semwal (1); rhkramer (3)
