Previous in Forum: What Would McGiver do.   Next in Forum: Wood Screws for Attaching Brackets to Oak Door
Solenoid Help
03/20/2011 8:04 PM
Hi, Im creating a stamping device and im really struggling to find a solenoid for my product. Im looking for a 12v linear push action solenoid which has a stroke of 10-15mm. The solenoid would be used to move the stamp head an mark the documents, therefore i need it to have enough force to move the 75g head and mark the paper. Any help would be much appreciated as ive been searchin for ages and can't find one that doesn't require bulk buying.
This is the version i have at the moment but it isnt powerful enough:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0347652
Re: Solenoid Help
03/20/2011 8:29 PM
How about this (from the same supplier)?:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2501303
Or something from Farnell?
Don't think you're looking hard enough .
(You do realize that you can mechanically limit the stroke, I hope?).
Good Answers: 918
Re: Solenoid Help
03/20/2011 8:32 PM
McMaster-Carr Part Number 69905K48
If you need a 3-D CAD model, private mail me.
Re: Solenoid Help
03/22/2011 3:48 AM
Have you tried going to your local auto parts store ?
Think retrofit kit for door locks and trunk releases.
" Is it plugged in ? " ... " Are you SURE it's plugged in ? " ... " Is it plugged into an outlet that is on a switch ? "
Re: Solenoid Help
03/23/2011 12:05 PM
See Zoloda's page "electroimanes" (solenoids):those are so strong.-
Re: Solenoid Help
03/28/2011 12:11 AM
If you have access to machine tools you could modify the mounting of a large car starter motor solenoid. Say from a big block Chevy. It will draw a lot of current and need a good ( truck or forklift ) battery, with an overnight charge. If you are doing a lot of stamping think air instead of electric. A small air cylinder will operate at a fast cycle for a lot longer, due to less heat ( at the cylinder end ). i.e. the heat will be at the compressor, possibly outside.
The air cylinder can be actuated by a solenoid pilot valve to give you the same sort of control system.
Anonymous Hero (1); ferquiza (1); JIMRAT (1); JohnDG (1); thepackrat (1)
