Previous in Forum: Solenoid Help   Next in Forum: A Reversible Universe?
29 comments
Wood Screws for Attaching Brackets to Oak Door
03/21/2011 12:54 AM
I stumbled upon a beautiful glass/oak restaurant door that I purchased from a reclamation company. I have drawn it out and attached the files below. The weight of the door is 80 lbs. It will be attached to 2 brackets, illustrated in the other drawing, and the door is suspended from them and slides on a barn door track system. This will be used as an entryway into my master bath. Where it says Bolt Hole it should have been written Screw Hole.
I have a few questions regarding attaching the brackets to the top of the door.
1) Location of the bracket: I know it is highly discouraged to screw into the end grain of wood, but I am not certain that it is best to suspend the door from the middle top section, either. What would you do?
2) Should I go with one or two holes in the brackets?
3) What should the diameter and length of the screws be?
4) Is there an option I am missing? I don't want anything mounted on the face of the door, so it has to attach at the top. Also, all of the weight must be suspended from the top as there will be no track or support structure on the floor underneath of the door.
I don't want to mess the door up guessing on the hanging of it. Please help.
Pathfinder Tags: brackets door screw wood
Engineering Fields - Power Engineering - New Member Engineering Fields - Military Engineering - New Member Engineering Fields - Construction Engineering - New Member
Re: Wood screws for attaching brackets to oak door
03/21/2011 1:22 AM
Hey 3rdnrl,
It's common practice to mount the top mounting , door suspension hardware in the end grain of the door stiles. This is not a particularly heavy door you have described.
A few suggestions to make it a successful installation:
Pre-drill the holes where the screws attach the hardware to the door, sizing the bit to the screws to achieve maximum support. Use some lubricant on the screws (soap, wax, etc.). Oak is strong, but it is also hard, not pre-drilling could result in the wood splitting or even the screws breaking or stripping out the heads.
I can't make out the details of the drawing, but if you are using a manufactured door slide and hardware , the instructions should indicate where to mount. If not I would suggest mounting the hanger around an 1 1/4" from the end of the door, keeping the mounts as far to the edge as possible will assist in preventing the door from rocking up and down as it is opened and closed. If the mounts are too close to the center , pushing on the door at latch height can make it pivot up slightly on the opposite side. This makes a jerky, bouncy movement of the door instead of a smooth glide.
usaully there is a guide mounted on the floor or door jamb to stabilize the door at the bottom.
... get yourself a pair of cheap sunglasses
03/21/2011 11:50 PM
This is a design of my own making, so instructions are made up along the way. There will be a guide track routed into the bottom of the door, with a guide pin mounted onto the floor, to keep the door from swaying side to side.
Thanks for the heads up about spacing them as far apart as possible. I had completely overlooked the rocking effect possibility.
03/21/2011 7:55 AM
I'd use 2 screws for each bracket, size 10 x 2" or 12 x 2", stainless, 'phillips' panhead. I don't see any reason to offset them as your 2nd bracket dwg shows; I'd have all 4 screws in the same line. I'd make matching holes in the farside of the bracket so the screwdriver is in line with the screw when I attach the bracket. (I'd use a screwdriver bit in my drill, and I'd set the torque to an intermediate setting initially using just enough torque to install the screw and avoid stripping the thread.)
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
03/22/2011 9:08 AM
The offset is better as it does more to prevent splitting of the wood.
If necessity is the mother of invention then is laziness the mother of necessity?
Re: Wood Screws for Attaching Brackets to Oak Door
03/21/2011 4:04 PM
As long as your door is structurally sound, you can pendant the door just fine. It is done that way often.
Have you devised some custom track system? I have not seen brackets as illustrated used for sliding doors.
Most manufacturers of sliding hardware suggest the hangers and trucks be mounted about 6" from each edge. This can vary with the track configuration, so be careful.
Screw size for attachmant? You have not given us a whole lot to go on... screws provided by manufacturers of sliding door hardware are #10 or #12 wood screws, about 1-1/4" or 1-1/2" long. Most decidely 2 screws at each hanger minimum.
03/21/2011 11:39 PM
I looked at the various systems out there and decided to experiment. This is the idea I came up with. Hope it shows you the concept.
03/22/2011 6:34 AM
Consider the torque on the bracket caused by friction against the sides of the roller. You need to at least extend the bracket along a section of the top of the door to hold the roller rigid/parallel to the runner.
03/21/2011 10:35 PM
#12x2" SS oval head Phillips 1 1/4" to 1 1/2" from edge of door to edge of bracket, centered, screw holes pre-drilled with a 1/8" bit.
Good Answers: 120
03/21/2011 10:39 PM
what I would suggest is a paid of load spreading plates, with 6-8 one inch screws into the end grain. These will be about .1 inch thick. The suspension brackets can then be attached to this plate with welds or countersunk screws from the other side.
This will give a robust suspension. An 80 pound door swinging can create a lot of force and the 2 screws into the wood might be torn out after a while.
Per Ardua Ad Astra
Good Answers: 74
03/21/2011 11:16 PM
After all that you might want to ad a stained glass (lead light) window. Just sayin', Ky.
The Twain Has Met
03/21/2011 11:44 PM
Never had a chance to consider the chameleon - the rice paper window film had already won out with a single vote cast by the wife.
Good Answers: 74
03/22/2011 1:00 AM
Yeah, they do that. Looks like it will be up and running soon. Send us a pic, Ky.
The Twain Has Met
03/21/2011 11:19 PM
First thing I would do, is to take a regular # 12 WOODSCREW, with shoulder, et al, and try it first into the end grain of the stile- Use a proper sized screw diameter, with a proper shoulder diameter-Bash it about a bit- Move it around--See how easy it seats, or if it is too easy to sink---If there are concerns, what we do , is to drill a 3/4 inch hole into the end grain, insert a 3/4 inch DOWEL, down 1 1/2 inch, using epoxy glue, saturate the wood around it with epoxy, and let it set for 24 hours. Then re-drill/countersink the proper size and set the screws--Old doors often have the end grain being the most vunerable over their lives, having been under sealed, and over exposed to the conditions and therefore, the least able to hold a proper fastening, in present time. This has worked well on double swinging kitchen /pantry doors , and entry doors ,up to 4 feet in width , and weighing at over a hundred and twenty pounds a piece--Make sure you stabilize the end grain before putting a lot of time and effort into it--Good luck, and let us hear on how it came out..
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
03/22/2011 8:36 AM
I have used the dowel method with much success BUT I drilled the holes for the dowel into the side edges of the door 6"deep and 3/4" down from top of door. That way the bracket screws are biting into the side grain of the dowels.
Nothing is fool-proof to a talented fool
03/22/2011 5:13 AM
I have hung many doors from screws in the top. Pocket doors. I recommend Johnson Hardware
If you going to do a job, may as well do it right. I assume that's why your seeking the perspective of others. I have used these kits many times and others that just aren't worth mentioning.
Johannes
03/22/2011 7:36 AM
I agree, use standard pocket door hardware and you should have no problems. The system is made to do just what you want.
03/22/2011 8:53 AM
GA from me.
Johnson Hardware is the cats meow. (I use them often) They went through the testing phase a long time ago and have gotten it right.
OpMan
03/22/2011 10:16 AM
You may have missed that this is not a pocket door. As I described in the original post it is a barn door type track so the door hangs external of the wall.
03/22/2011 6:30 AM
Oak Door.. You should not have a problem with end grain mounting.. The wood will be well seasoned by now but look at the end grain to make sure you have it the right way up The top will be a different colour and give yourself 1/2 of the rail from the edge before you drill. Also only use brass screws..looking at your drawing I would say no less than 2 1/2" or more. Mark a centerline and then pre drill 1/2 the width of the top shank of the screw the whole depth of the screw .. To avoid splitting do not use twin-fast or screws that have a thread all the way up rub some candle wax or grease (animal ) on the screwthread to assist the screw on the way in and remember when fitting the bracket you may have to use a ratchet set because there is no hole in the top of the bracket for screwdriver access use the correct screwdriver bit for the job and countersink the bracket..Hope this helps you..
Torque is not cheap
03/22/2011 10:17 AM
Why brass over stainless steel as other posters have suggested?
03/22/2011 10:41 AM
Brass was suggested in lieu of carbon (plain) steel screws. Iron will react with the tannin in oak, and turn the wood blue.
Unless your door is very custom, it is in fact an oak veneer over a parent wood. The caution about fasteners is not applicable if located in the parent wood of the rail.
03/22/2011 11:23 AM
It is solid oak (no veneer) so brass is the best choice then?
03/22/2011 11:44 AM
Brass, stainless steel, or unobtanium screws are indicated.
Good Answers: 11
03/22/2011 9:41 AM
I'm not an engineer, but I am an interior designer, and I can tell you that pocket doors that get a lot of use can end up being a problem child over the long run. First, you must make sure that you have sufficient clearance behind the wall so that the wood can expand with moisture (especially in a bathroom) or it will rub against anything back there (i.e.: nails in the studs). Also, just a thought, but have you considered a recessed track in the floor? I am not a fan of suspended anything (nor of cantilevers).
03/22/2011 10:51 AM
I'm in a hurry so have not read all comments. I've hung many doors in the situation you are describing. Use #10 or # 12 pan head sheet metal screws 2" or more (they have thread all the way for better holding strength). Size your bit carefully, best of luck.
03/23/2011 11:25 AM
03/26/2011 7:42 AM
If you are screwing into end grain, you want to avoid splitting the wood. Use a fairly long screw. Pilot drill a full diameter hole about an inch deep. Drill a further pilot hole equal to the root diameter of the screw to the full length of the screw. Sharp threads are best; they will cut into the wood rather than "trying" to spread it. Number 10 or 12 screws about 2.5" long should be good. Tighten the screws snugly, but do not "reef" on them. I would use at least two screws per hanger.
I have seen data on the holding power of screws in either end or side grain, but alas I forget where.
Ireland - Member - New Member Engineering Fields - Energy Engineering - New Member
03/26/2011 10:53 PM
Most of the posts have referred to pocket doors. From your diagrams it would seem you are hanging the door from a track and in your OP you say there is no corresponding track at the bottom. So what stops the door swinging in from the bottom? Consider how an 80lb oak door would be conventionally hung; 3 x 4" hinges with 4 x 1 1/4" screws = 15" of screw thread. The hinges are installed in rebates so the screws carry less weight. And a lot of the weight is applied as a shear (i.e. across the screw). Now you are hanging the door suspended only by the screws with the force applied axially (along the screw length), in end grain. You will find that the door will operate OK for a while, but in time the screws will tend to pull through the end grain. The consequences of screw failure could be significant, if a glazed door were to fall on someone for example. I would: - use as long a screw as you can find (3-4") - use at least 2 per bracket - screw them at a slight angle ("on the tosh" as joiners say), so some of the force is resisted as shear - use stainless steel (steel will corrode in oak, brass is not as strong) - consider lag screws (large screws with bolt heads) Just my ha'pen worth.
I love deadlines; I love the whooshing sound they make as they pass by. - Douglas Adams
03/28/2011 1:08 AM
I suggest you will need to make a bracket similar to Randalls #18 so that you can get more screws in. Also skew screw. As you are making the bracket skew the countersink to the same angle.
Choose these screws. They are often called decking screws. Technically type 17, countersunk, square drive stainless steel #10g 2" or #12g 3"
The ones on the left are often called chipboard screws T17 c/s #10g 3" class 3 . ( This is a weather resistance classification. ) Class 3 is galvanised, "climaseal" etc.
The sq drive is better than Phillips but still it will 'strip'. If your driver strips the head, back out the screw immediately and discard. Don't ask me how i know that this is the best option.
I SAID DON'T ASK!!!!
There you go again, O.K. i've done a lot of decking, I don't want to be reminded O.K.
One last thing, you need to decide to go for maximum holding power first up and use 3" or to go 2" and leave room to put in longer screws when they come loose.
Oh! another last thing. The ball roller bearings you are using in the routed "track" will chew up the wooden side of the track showering you with wood wool as walk through. Take a tip from the manufacturers and use two bearings ( to prevent skew ) or better still place a small roller guide ( or nylon slide ) to keep the ball bearing away from the sides.
Have fun
Jim
Register to Reply 29 comments
129CBRider (1); aurizon (1); BabyGuinness (1); C-Mac (1); Doorman (3); double_j_b (1); Hornetson (1); JIMRAT (1); Johannescnc (1); ky (2); lonster (1); Major Elkie (1); merc600sec (1); OpMan (1); Randall (1); specifier (1); thirdnrl (6); Tom_Consulting (1); Tornado (1); Usbport (1); westbye (1)
You might be interested in: Door Operators, Door Stays and Lid Stays, Garage Doors
