Previous in Forum: NH3 Boiling Point   Next in Forum: What is Material C22.8 Part 6?
10 comments
Separation of Crude Petroleum From Sea Water
03/22/2011 11:22 PM
I need to separate crude petroleum from sea water in order to agreed with federal regulations, the mix is already in a 1000 gal tank, since one year ago. I will appreciate your help. THANK YOU ANTONIO CONDE
SALTS FOR BABBITING
Re: Separation of crude petroleum from sea water
03/22/2011 11:41 PM
antonio; doesn't oil float on water, skim off the oil down to the water level & add more oil
03/23/2011 12:57 AM
Distillation, filtration, centrifugation, absorption and evaporation will all work.
Anonymous Poster #2
Re: Separation of Crude Petroleum From Sea Water
03/23/2011 8:43 AM
Antonio
GOOGLE the terms "oil water separator" and "desalter".....you will find devices an systems that will help you.
What kind of a tank is being used ? ... Carbon Steel ?
There may not be much left of your tank after 1 year........ consider replacement with an oil water separator.
Please respect us...... complete this thread by telling us of your final solution
03/23/2011 11:03 PM
In first place I want to expres my gratitude to a person I do not know, your lines put a great light in my proyect. Yes I'm using a Carbon steel tank.
SALTS FOR BABBITING
03/27/2011 10:44 AM
Gravity will do it, given enough time. The water will drop to the bottom of the container and the crude will form the supernatant layer. Turn the agitator off!
05/10/2011 10:51 PM
Dear antonio,
I just read your post... For your information there is another technique has been used and I ever seen in the internet that Human hair can used to absorbed crude oil in the sea water. Separate in your word means remove right. So maybe this website could help your problem http://www.ehow.com/how_4480375_remove-oil-from-water-using.html
06/16/2011 2:09 AM
hi zunaida,
I've followed up your post and you are very informative. Thanks for the info
06/16/2011 2:22 AM
You are most welcome
06/17/2011 2:51 AM
zunaida,
maybe u can help me out. How to increase the MFI (melt flow rate) of ABS. I have ABS with MFI 20 g/10min. Is't in any way possible to increase it to 30 g/10min with help from agent or something?
06/17/2011 3:02 AM
Dear mdjayham
To increase the MFI for the materials, maybe you can use lubricant..it can make your material easy to processed and flow. sometimes, we can use the recycle materials..but its depend on the application.some application is not suitable to use recycle materials. Recycle materials have thermal history..that is why it can used to reduce the MFI value. Hopefully this could help you or you can ask who are expert in this area...
Register to Reply 10 comments
Anonymous Poster (2); antonio conde (1); lyn (1); mdjayham (2); PWSlack (1); zunaida (3)
