Previous in Forum: E-mail From a Tokyo Policeman to My Sister   Next in Forum: Sigma Phase and Surface Cracks in 317LM Grade
29 comments
DIY Junction Box or Solar Combiner Box
03/23/2011 2:13 AM
I'm building a small solar farm and I'm looking to save costs with out sacrficing saftey and quality, for example
Solar farm combiner boxes and junction boxes are very expensive, and I have found Govt' Surplus Ammo boxes to be of similar gauge and quality, with a significantly lower cost. I have talked with some Solar farm builders that are manufacturing they're own combiner boxes to reduce costs, they are staying with in NEC spec and so would I.
Just thinking and wanted the groups opinion and if this is possible I could use some help on NEC compliance.
Spacecannon
The person who wrote the above is not resposible for spelling, grammar or puncuation, ......
Re: DIY Junction Box or Solar Combiner Box
03/23/2011 11:22 AM
To start with, just so I clearly understand what you're talking about, you want to use Govt' Surplus Ammo boxes as electrical junction boxes, right?
When I was involved in industry, most of the people responsible for code enforcement or interpretation (the "authority having jurisdiction") typically required boxes NEMA rated for the area--well, in fact the National Electric Code requires that).
So, if there is an "authority having jurisdiction" over your application (often the chief of the fire department), you would need to get his approval to deviate from the code.
OTOH, I can imagine that a Govt' Surplus Ammo boxes could be adapted to make a quite safe electrical junction box, giving appropriate consideration to its location and environment. (E.g., make sure it is raintight if outside, use appropriate fittings through the box to avoid abrasion of cable installation, suitably marked (and located, and fastened closed) to avoid kids playing in them, etc., etc., etc. ... )
So, if I lived on a farm, I'd consider using such things in places where fire insurance is not an issue (even if not approved by the "authority having jurisdiction")--maybe outside of any buildings. In buildings, I'd be careful, for fear of losing insurance coverage or similar.
But, I won't really make or stand behind such advice, because there are, quite likely, legal and liability issues.
If you have total control over all the related issues, you might make a decision for yourself. You may have to look up the specs on NEMA rated junction boxes for various locations to confirm that you have properly considered those.
03/23/2011 1:46 PM
GA, excellent advice, I received additional advice, this morning and It appears that an empty box does have to be UL listed even though it is Gov't spec airtight already.
Thank you for your opinion.
Im wondering if it would be possible to use a large junction box and add the connection rail, Junction boxs are 1/4 of the price of solar combiner boxes, what do you think?
03/28/2011 9:00 AM
Well, at least as far as the enclosure, that should be no problem.
You'd have to make sure that what you put in the enclosure also meets all appropriate standards (like ratings of breakers, size of busbar for the load, ...)
03/23/2011 10:50 PM
I don't know if this would be acceptable, but what about using indoors UL rated boxes - ie designed to be used in a roof space - and then having an inexpensice but durable weatherproof enclosure over them to provide the 'indoors' environment....
Just a thought
03/24/2011 12:05 AM
Maybe, GA, I'll ask around, unless someone here knows the answer.
03/24/2011 6:43 AM
03/24/2011 7:36 AM
I like that, but make sure you use a romex connector or grommet to protect the conductors entering/leaving the enclusure and that you get a panel suited for the installed location. Also, this is not the "intended use" of an electrical panel, so run it by the AHJ just as you would have for the ammo box idea just to be safe.
NEMA 250 is the standard for enclosures. If you want to intelligently make your case for the ammo box, read it and prove that you substantially meet the requirements. Although regarded as such the NEC is not in fact the law, your local AHJ who will inspect your installation is.
He who laughs last thinks slowest.
03/24/2011 7:42 AM
this device has so many code violations it would take a while to list them all, but the primary, and most important, is that you are using AC breakers for DC voltage and current. This has probably been the most common error made in all DIY projects.
03/24/2011 8:23 PM
AC breakers. Here in Australia, most domestic AC breakers can be used in a DC circuit. Thermal and magnetic overload detection, are usually the 2 defined ways for protection.
A de-rating factor of 80% is a common nominal correction.
Up to a DC Voltage of about 50VDC.
But..........Check the particular specifications for the Brand of breaker........!
Cheers
Mark N.
I dislike "Anonymous" intensely. It is like they have something to hide? Their Cowardice.! I also dislike those Who will not help themselves, by not replying, to a civil Question.
04/07/2011 4:43 AM
Mark, I do not understand your reply to this thread, I thought this was about enclosures not circuit breakers.
04/07/2011 6:52 AM
Read PFR's post #7 which Mark was replying to.
Good Answers: 114
03/24/2011 10:00 AM
This is a decent solution, the expensive part is the connections. any breakers end up being disconnects, since individual solar panel, won't be putting out enough power trip a breaker like these
all the wires should come in from the sides or bottom. you can't really make panels water proof, better to accept that there will be water & direct it away from the connections
It depends on how many connections you need to make, how often you will need to access them, if you need to be able to isolate individual panels
here's a different way to goSafety Switch
you might be better off with a traditional enclosure
I can help you figure this out here or by email
03/24/2011 1:23 PM
GA, Garthh,
I guess you know my story, the utility companies are not really paying enough to make solar work commercially. Everyone says it's all working, but the truth is the solar developers made all these proposals based on prices comming down. Most of these farms will get built and be found to be unprofitable. Mine is the cheapest I have seen and it is currently only projected to make investors 10% and they all want 15% ROI.
Thanks for you advice, you rock!
I'll be in touch.
Spacecannon
03/24/2011 1:07 PM
Randall, GA,
This seems brilliant, but I'm an amateur, thx
Good Answers: 58
03/24/2011 8:59 AM
Code compliance is one aspect of your project. There is also a technical side. Military ammo boxes and NEMA enclosures are not vapor tight. This means that water vapor can permeate through the organic seals and raise the dew point of the internal space. All it then takes is for ambient temperature to fall below the internal dew point, and water will condense on the coolest parts. So, the longevity of your boxes will depend on the outside environment. The better way involves either hermetic sealing with dry gas inside the seals, or continuous purging with a dry gas.
03/24/2011 9:29 AM
Just a note to confirm that because you are building on a farm, you may be able to adjust some building inspection requirements and equipment, but if you are going to grid tie, your system will need to comply with NEC, at least where we build PV systems.
03/24/2011 1:14 PM
GA, Yah your right, When i say farm I mean a 1.1Mw PV, Grid tied, commercial solar farm, in the desert.
03/25/2011 6:35 AM
Yes, they are ridiculously expensive. I build my own using positive and negative copper bus bars mounted on insulators then the bus bars are drilled and have screw down terminals bolted at even spacing for each solar panel set. You then cable a single heavier guage wire from each bus bar down to your controller. Naturally you can only combine as many panels for each group as your controller can accept. In my small system I only needed 1 combiner.
As far as codes go I don't know because I live in the Dominican Republic where codes are few and far between but for high voltage arrays above 24V you should fuse each positive down feeder for your own protection.
John
Good Answers: 58
03/25/2011 6:53 AM
I am involved with some advanced thinking in PV technology. One of the concepts involves putting DC/DC converters at each panel so the output voltage will be considerably higher and the power bus losses much lower. This will require reliable weather proof converters, but the economics are promising.
03/25/2011 8:49 AM
Is DC-DC conversion more economically feasable than simply using series strings which work at high voltages (400-600VDC)? It would seem to me that the DC-DC conversion is unnecessary and would add losses?? Correct me if I'm wrong.
John
Good Answers: 58
03/25/2011 7:27 PM
John, I'm far from an expert in these matters but as I understand, it has to do with reliability. If you series up a bunch of PV panels and one of them fails, you have real urgent problems. In parallel, you have more flexibility
03/26/2011 8:07 AM
I've had a fair amount of exposure to whats going on, but won't claim to be an expert. In large thin film arrays where each panel has a Voc of 135VDC you only have to put a few in series before you have a high enough voltage for modern grid tie inverters. So you would have dozens of groups in series/parallel. Using good construction techniques failures are not very common and even in the event you would only lose a small group. The person asking the question says he's doing a MegaWatt array which is huge and most likely thin film unless he has space restrictions. So he needs to do a whole lot of combining with that many panels and custom combiner panels may be a cost saving issue for him.
I've also looked at panels which each have a tiny inverter on them and the AC outputs are all combined and synchronized for grid tie. This saves all the DC wiring and expenses incurred. He may want to consider this also.
John
Good Answers: 58
03/26/2011 11:09 AM
I like the idea of the tiny inverter but my people tell me that reliability issues have prevented that method from being widely accepted to date. To be practical you are going to need small electronic assemblies that can operate reliably in all kinds of environments for long periods of time. I believe it can be done, but it's not a trivial task.
03/26/2011 12:54 PM
GA, yes, thin film, ground mount.
Good suggestion on the small inverters, and I looked into it, it's not as financially feasible. It increases the cost per watt and the number of parts that can go wrong.
Good Answers: 58
04/07/2011 7:56 AM
I don't want to put words in your mouth but I think you agree that a reliable, low cost inverter would solve your problem.
04/07/2011 8:10 AM
It's a tough thread, but to boil it down, OP wants to build what he is calling small PV farm using home made combiner boxes. Turns out he is talking 1.1 megawatts. While it has been interesting, it's pretty sketchy.
03/25/2011 12:14 PM
DC/DC converter?
still limited NEC 600 VDC on residential,
if you are talking commercial, and go to 1000 VDC (pretty much PV panel limit), then converting higher, then inverting AC lower, that would be a rare solution. (As in losses from upconverting being less than reduced transmission losses)
Are you talking miles?
11/12/2011 1:13 AM
I would love to be running a solar panel and battery system but the wife says they are ugly and doesn't want to spend $65,000! There are many solar sites and companies out there. Most States require a State approved system as do many local utilities that offer power buyback and incentives. State and the local utility incentives in Texas are quite friendly.
Solar Panels Georgia
11/13/2011 11:50 PM
Yes, wish I were living in Texas.
Register to Reply 29 comments
andrewstone81 (1); Garthh (1); Joe Sparky (1); JOHN H VAN ALLEN (3); Markone (1); PFR (4); Randall (2); rhkramer (2); RonCu (1); spacecannon (7); WAWAUS (1); welderman (5)
