Previous in Forum: Stirling Engine   Next in Forum: Ventillation Ducting
Material Selection - Modification
03/23/2011 7:02 AM
my Generator radiator water sump gets dirty all the time and requires regular cleaning. the drain point uses a 3/4 inch pipe. i want to open it up at the side by 300mm X 300mm. the tank steel thickness is 5mm and i intend to use 3mm steel plate as a cover for the port. question is, what type of bolt, size and number do i require. what gasket type.
Re: Material Selection - Modification
03/24/2011 12:06 AM
If you put the plate inside the cut-out, you wouldn't need more than 4 on a side. Some silicone or liquid gasket would seal it fine, with the pressure on the inside.
No need for a separate gasket.
Reply to Forum Thread
