Previous in Forum: Material Selection - Modification   Next in Forum: Centrifugal Pump
Ventillation Ducting
03/23/2011 10:17 PM
Any one please Explain what is DRYWALL PARTITION in ducting.Is it same as Fire rating of ducting or different.
Pathfinder Tags: duct
Re: Ventillation Ducting.
03/24/2011 6:22 AM
Drywall, also known as sheetrock or gypsum board is referring to the substrate that the ducting passes through. The wall itself..........not the ducting.
There may be a flanged fitting that attaches to the drywall to help support the ducting.
You might be interested in: HVAC Ductwork, Wallboard, Access Doors
