Dear Sir,
My question below refers to the routine tests to be performed on current transformer [ characteristics : rated voltage 245 kV; frequency : 50 (fifty ) Hz ; rated current : 2.000 A] :
Suppose in the following situation : the current transformer with the characteristics above will be tested at a high voltage electrical laboratory which is configurated to perform test only in the frequency of 60 [ sixty ] hertz [ not in 50 Hz ].
In this case, what are the conditions, modifications , correction factors that I must consider for performing the routine tests below [ according to the IEC 60044 and/or IEEE C57.13 standard ] ? :
a) Power frequency withstand test ;
b) Parthial discharge;
c) Capacitance and dissipation factor;
d) Inter turn overvoltage test;
e) Accuracy test;
f) Excitation curve.
Note : The laboratory has only equipments and instruments for the frequency of 60 Hz, but the current transformer to be tested has 50 Hz frequency.
Thank you in advance
Cláudio Morais
