Previous in Forum: Moulded Scratchproof Transparent Glass Manufacturing   Next in Forum: Calorific Value of EN8
Material Translation
03/25/2011 4:48 PM
I'm working on a quote to fabricate replacement parts for a hydroelectric turbine and I need help on a couple of the materials. I'm not sure what these two materials convert to: GSnPb Bz717 and GBz14. Please help if you can.
Thank you,
Gene
Pathfinder Tags: materials
Re: Material Translation
03/25/2011 7:16 PM
My crystal ball says:
Our standard alloys acc. to DIN EN 1982 - Copper- and Copper alloys
Copper-Tin-Alloys
Chemical
Numerical
Material No.:
Use
G-CuSn6
( Gbz 6 )
2 1020 01
Used in the electrical and chemical industry.
CuSn10-C
( Gbz 10 )
CC 480 K
2 1050 01
Fittings and pump housings. Guide, running and blade wheels for pumps and water turbines.
CuSn12-C
( Gbz 12 )
CC 482 K
2 1052 01
Material with good wear resistance. Good corrosion and seawater resistance. Coupling pieces, clutch stars, spindle nuts, worm gears, housings.
CuSn12Ni2-C
( Gbz 12Ni )
CC 482 K
2 1060 01
Highly stressed fittings and pump housings.
G-CuSn14
( Gbz 14 )
Gbz 14
And
Seismological Bulletin
CHBR BZ 717 98 EPn 1023
Without any real idea what you are doing that's all I can find.
Looks like a material spec and a seismic spec.
03/26/2011 6:51 AM
Thank you, lyn.
I'm going om a site visit wednesday and will try to locate an original BoM. The Hydroelectric plant owners, to whom my rebuild quote will be submitted, are getting no response from the original manufacturer. I wish not to use substitute material(s).
03/26/2011 2:30 PM
That's what i call a good answer!.-
Good Answers: 48
03/25/2011 8:18 PM
I used to have access (many years ago) to a publication called "Stahlschlussel" (literally 'key to steel') which cross-referenced materials from special cast-irons to high-grade chrome/nickel alloys between English, American, French, German, Japanese and other designations. I have not been able to find it online, except to buy, but it would certainly tell you what you need to know. I suspect GBz14 could be an Aluminium Bronze, but I don't recognize the other. Can you not get the material specs from the turbine manufacturer? Or is it all in Russian?
03/26/2011 6:55 AM
Thank you, Holtzfeller,
Gene
Good Answers: 243
03/26/2011 11:30 AM
Hi Holzfeller.
I have an older version of Stahlschlussel, as well as Worldwide guide to equivalent irons and steels and Worldwide guide to equivalent nonferrous metals and alloys and a couple other great references, plus my own info.
But as lyn has just shown us, sometimes just working online can get you what you need.
Have a great day all.
Milo
Register to Reply 6 comments
ferquiza (1); Gene Schoonmakerfranczek (2); Holzfeller (1); lyn (1); Milo (1)
