Previous in Forum: Maintenance for Static Switches   Next in Forum: Magnetic Motor Starter
9 comments
Designing a Frequency Meter
04/07/2007 7:22 AM
Hi Engineering world
I'm working on a project that I have to design a frequencymeter that can provide me a frequency between 1 and 5Hz.
Anyone is welcome for my help.
Regards
Impossible n'est pas Camerounais
Re: Designing a Frequency Meter
04/07/2007 9:28 AM
Is this to measure 1 to 5 Hz frequency or to generate it?
Also what accuracy do you need as well as display analogue or digital??
What is the signal required to be generated or measured? is it large or small voltage, sine, square, or pulse?
and so on... John.
04/07/2007 1:21 PM
Hohh thankx man this is to generate a frequency between 1 and 5Hz as digital square wave small voltage
04/07/2007 9:40 AM
Frequencymeter? Frequency generator? What wave form Variable or fixed? Logic level or ?
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
04/07/2007 1:29 PM
Yes man I'm talking about frequency generator that can generate me a frequency between 1 and 5Hz(variable).I need a square wave in digital logic.
thakx
04/08/2007 7:53 PM
You can generate pulse waves not square waves with the 555.
04/08/2007 8:21 PM
You can get a 50 percent duty cycle, if that's important: see
http://cr4.globalspec.com/thread/6358/555-timer-design, post #11
04/09/2007 9:49 AM
Yes but it is still only pos going pulses. 555 can not on it own give true rms square wave out.
04/07/2007 10:37 AM
04/07/2007 10:55 AM
Register to Reply 9 comments
Anonymous Poster (2); BrainWave (2); Electroman (1); nganpet (2); SolarEagle (2)
