Previous in Forum: How to Check Vacuum Gauge Sensor   Next in Forum: IEC Standards
Checking Accelerometers Using Vibration Equipment
03/28/2011 9:29 AM
Is it possible to check accelerometers using TK3 Vibration equipment.
If so could you let me know how such is performed.
Coz at my present site the client have separately a TK3 for axial and radial vibration and a wobbulator for accelerometers.
So could you confirm to me whether TK3 is enuf for checking all i.e radial, axial and accelerometers.
Venezuela - Member - New Member
Re: Checking Accelerometers Using Vibration Equipment
03/28/2011 4:00 PM
Friend Clintdsa,
The TK-3 is not designed to test the accelerometers, you can use it to test axial and radial probes (proximity sensors), the wobbulator is used for simulate radial vibration in order to check the input signal to the monitors showing radial vibration and also can be used to check the keyphaser.
You can also with the TK-3 create the calibration curve to the proximity probe+extention cable+proximitor.
In order to check the accelerometers, I can recommend this equipment: Portable Vibration Calibration System Model 9100C (The Modal Shop, Inc), I received this suggestion from the Bently Nevada technicians.
Hope this helps
J.P
Instruments-guy-SAV
03/28/2011 11:43 PM
It has been simply ages since I messed with accelerometers--we got our graphs by pen and ink on a moving paper. If your acceleration is in the ballpark of 1 or 2 g, you should be able to turn it upside down (or is it downside up?), and it will indicate a 2g change in the acceleration.
Lehman57
Register to Reply 2 comments
