Previous in Forum: Boiler Feed Pump Abnormal Sccop/Speed variation   Next in Forum: Checking Accelerometers Using Vibration Equipment
How to Check Vacuum Gauge Sensor
03/28/2011 7:32 AM
I have vacuum gauge , model thermovac TR211 and controller TM21
it is not working and shows no sensor . i want to check the sensor.
it has 6 pin. i want to what is input and output and which pin input and output.
can you anybody help
Re: how to check
03/28/2011 7:34 AM
....and the reason the equipment's operation and maintenance manual cannot be consulted is what, please?
And the reason the equipment supplier cannot be contacted directly is what, please?
Re: How to Check Vacuum Gauge Sensor
03/29/2011 3:03 AM
Hi, hiteshpurani,
The integrated sensor comes in three configrations, all 6 pin. So what ever you have in your equipment, match it with and test what you can.
Here are the pin configrations depending upon configuration.
case 1 :
PIN 1. VOUT
2. GROUND
3. VCC
4. V1
5. V2
6. VEX
case 2 :
PIN 1. OPEN
2. GROUND
3. -VOUT
4. VSUPPLY
5. +VOUT
6. OPEN
case 3 :
PIN 1. OPEN
2. GROUND
3. +VOUT
4. +VSUPPLY
5. -VOUT
6. OPEN
Thats all , Have fun.
Register to Reply 2 comments
