Previous in Forum: JIS Pipe   Next in Forum: ASME PWHT
Compressor Design and Selection
03/29/2011 3:14 AM
I want to select a flash gas compressor in oil and gas industry. Since the amount of flash gases has increased from 1 MMScfd to 4.3 MMscfd therefore, we have to install another compressor in parallel with existing one (Max Capacity = 1 MMScfd) to cope the increased flow of flash gases. Furthermore we want a rental compressor.
In the light of above discussion I need comments for compressor designers and suppliers that what steps and procedures shall I take. What data/calculations will I have to be shared with designers/suppliers.
Pathfinder Tags: Compressor Selection
Re: Compressor Design and Selection
04/04/2011 12:21 AM
You've said: Since the amount of flash gases has increased from 1 MMScfd to 4.3 MMscfd therefore, we have to install another compressor in parallel with existing one (Max Capacity = 1 MMScfd) to cope the increased flow of flash gases. Furthermore we want a rental compressor.
It seems your decision causes un-uniformity in process system. I think it's better and more efficient that you perform an Economic/ Technical evaluation about the Compression of TOTAL Flash Gas to get the optimum & uniform design before doing any decision about the increase the no. of compressors with different capacity from old one.
Required information for the vendor: You as client ( or your designer, consultant) have to prepare : Data Sheet mostly contained process information, the probable standard views as supplement to the standard accepted by vendor, P&ID( if required).
KAVOSH
