Simply, it is a feedback device to tell the controller that the signal sent to the valve actuator has set the valve to that signal position. It doesn't care about the process or flow through the valve, just that the signal has been acheived at the actuator and the valve actuator position matches the signal.
"Memorize the calculations, you look like a fool searching your notes while teaching class"
