Previous in Forum: 35 Tons Double girder EOT crane   Next in Forum: ASME II materials question
18 comments
Yield Strength of 316 SS
03/31/2011 5:08 PM
Hi All,
Is there an authoritative online source for looking up the mechanical properties of various grades of steel? In particular I'm looking for the yield strength of 316 stainless, and I've found various vendor data sheets with values ranging from 30-42 ksi.
I've tried Matweb, but the data contained there is also all supplied by vendors. Am I naive in assuming that there should be a standard industry value for this grade of steel? I know there can be other factors such as cold rolling and annealing that could effect the yield strength, but I'm planning on using plain old annealed rod stock. Any help would be most appreciated.
Tritium
Re: Yield Strength of 316 SS
03/31/2011 7:11 PM
If you're really, "planning on using plain old annealed rod stock" isn't 30-42 close enough? Is this something you have on the shelf? We don't know what it has to do.
If it's going on a spacecraft, you can get material certifications and even lot/batch testing/traceability data that attests the material is per some AMS/MIL/ WHATEVER specification.
Milo?
Good Answers: 101
03/31/2011 7:36 PM
Vendor data is about as good as it gets as the strength will depend on the particular metallurgy used to manufacture the material. There are standards that call out percentage of each ingredient that are allowable to call the end product "metal x" or "metal y" etc. but a very small difference in the ingredients can result in dramatic differences in material properties as well as the process used to get the end product IE cold drawn, hot rolled etc. Get the data for the exact material you are going to use from the manufacturer that made it. Err on the side of caution.
Good Answers: 243
03/31/2011 11:28 PM
I would mean no disrespect when I said yes i think that there is a bit of naivete in expecting multiple vendors and multiple sizes to have a single value of yield strength.
The percent cold work differs by size, and so smaller sizes would be expected to have higher properties than those much larger. I use SAE nominals for carbon and alloy, 1" rounds, and always expect different sizes, shapes, and vendors to diverge.
Nominal is nominal. As some else posted, if you need moon shot precision, spec it at time of purchase.
Repost with diameter and I will look up carpenter book values in the AM.
Milo
04/01/2011 8:45 AM
Thanks for your answers, seems like this more or less sums it up. I'll consider the range of values during my calculations and err on the side of caution, as RVZ717 recommended.
Milo, what is this "carpenter book" you mentioned? The diameter is 1".
Good Answers: 243
04/01/2011 9:15 AM
Pg 65 Carpenter Specialty Alloys Carpenter Stainless Steels Selection Alloy data fabrication guide. Copyright 1999
project 70 stainless
AnnealledYS 36ksi; annlld + Cold drawn 75ksi;
UTS annlld:82ksi; annlld +cd 96 ksi;
% elong Annlld:68%; annlld +cd 42%;
% reduction of area annlld: 76; Annld +cd 75;
Rockwell B mid radius Annlld 80; annld + cd 96;
Charpy V notch 240 ft/lb- did not fracture completely; annld + cd 140.
Like I said these are Nominal and would vary from heat to heat as well as by size from a single supplier; now throw in the variability in the whole wide world...
But in court I would use these data.
Milo
04/01/2011 4:56 PM
Milo, thank you! I think I'll have to get my hands on one of those books.
Good Answers: 243
04/01/2011 5:59 PM
Check your CR4 email.
Milo
Good Answers: 213
04/01/2011 11:23 PM
Engineering ToolBox is also a good place to look for "nominal" values...
Good Answers: 196
04/01/2011 11:52 PM
Tritium -- This is a hard thing to get across to a lot of American mechanical engineers, whose designs are not constrained by the building codes the civil engineers work under. You cannot rely on any published tensile or yield strength data for AISI spec steels. This is because strength is not part of the AISI spec. You get what you get.
Whatever strength, whether tensile, yield, fatigue or any of the others, are your responsibility will usually come for your use as an engineer only after you put some extra cost in your design. (with the heavy weight of some type of liability hanging over your head). Heat treat for carbon steels, rigidly specified cold work for austenitic stainless steels like your 316, buy something with a guaranteed spec you like or some other appropriate processing for other alloys.
You can do a bunch of homework on the effect of the allowable range of constituents and defect allowed in the particular steel you are dealing with. Or if you spec some more expensive proprietary form of the alloy you want and you rely on whatever the supplier will guarantee. That probably won't keep your company out of court but at least it will strengthen their defense.
You can rely on some "maximum working stress" or other rule of thumb (10ksi max for low carbon hot rolled steel) to keep you out of trouble.
Or you can make your design based on modulus of elasticity (which is well known for metals) and/or design the failure mode to be failsafe.
And here you though machine design was so straightforward when it came to metal failure....... Ed Weldon
Good Answers: 58
04/02/2011 7:43 AM
Frankly, I consider a handbook from an organization such as the ASM to be a more reliable source than a manufacturer's data sheet or a web based source. The Metals Handbook contains properties data in various conditions, and will also refer you to applicable specifications. When you are required to justify your work, web based data may lack credibility.
Good Answers: 11
04/02/2011 5:13 PM
ASME B31.3 for pipe material strengths. ASME Section II Part D for material strength for just about everything else.
These have some standard values for various grades of steel. Also, try a Metals Handbook.
Good Answers: 243
04/02/2011 5:27 PM
Meaning no disrespect to ASM or Metals Handbook, or any of my fellow commenters, but much of that data is very old and from processes no longer employed. Ingot cast. Bessemer steels. Some volumes have been edited and revised, some content is just cut and paste from earlier versions. ASM is a prestigious publisher, And I have many of their volumes at hand.
But I would take a manufacturers data (AS I KNOW or can figure out the process and practice that made it) over a general book's numbers any day.
As I said, I'll testify on Carpenter's data.
Milo
Good Answers: 196
04/02/2011 7:07 PM
One other comment about manufacturer's data. Let's assume that as a responsible engineer for the design or analysis you decide that certain material properties are critical to your work. If your application involves enough sales volume of material to get the manufacturer, not the distributor, to answer the phone try and bore your way into their company materials scientists/metallurgists and find out just how good their data is.
What? Their metallurgists are not available to you? Then perhaps you are dealing with the wrong supplier. Most local metals dealers selling to industry are very conscious of this and are inclined to help you if you present yourself in any kind of professional manner. Eventually the working engineer can get very good at such presentations even though he may only be choosing material for a tool or prototype that will never be sold.
As mentioned above there are quite a few material specifications that are recognized in trade and common law as carrying some credibility. We mechanical engineers are familiar with ASTM, ASME, AISI and SAE specs. There are Milspecs if you work in that world . The EU and Japan have specs. There are also books published that cross reference the material designations of different countries. Copies of the actual specs are usually available only at some expense. You won't generally find them in full form on the internet. But if you are working at a professional level the expense of a copy is a trivial cost of doing business.
If your company has some austerity program going on and won't let you buy the specs tell you boss to mosey over to the corporate legal office and have a chat about product liability. The engineers also need some awareness of what sales and purchase contracts have to say about this general issue. A well managed engineering department will have these bases well covered within its skill and knowledge resources. Often this is not the case in startup companies; so be forewarned.
One of the reasons mechanical engineers take metallurgy courses at university is that the subject is complex. If you retreat into a mode of picking numbers out of a table and or just putting some generic name in the material block on your drawing then IMHO you are performing at less than the competence expected of a graduate engineer. What you are doing is throwing the responsibility ball over to non-engineers whose best tool for insuring company success is the legal contract of sale or purchase.
As to the ASM/Metals handbooks; I have no quarrel with them. I have a whole shelf in my library devoted to Editions 8 and 9 picked up cheap on eBay. My mech engr. son has in his library an entire later ASM series up to Vol 18, a lucky purchase from a company gone out of business. They are wonderful reference sources.
But you can't as a responsible engineer just go in there and pick out a number you like without an encompassing understanding of what it means. Every time I open one of those volumes I peruse a lot of material related to my mission to gain a greater understanding of the materials I am dealing with. And as Milo suggests you need to be able to filter the info you see there through your own knowledge screen. If you don't have enough basic understanding of materials science you are probably better off getting your advice from some other source.
Ed Weldon
Good Answers: 243
04/03/2011 11:52 AM
Bravo, Ed! Very well stated.
milo
Good Answers: 101
04/04/2011 4:13 PM
Excellent response, GA sir.
04/05/2011 11:32 AM
Ed, thanks for your insight. It is tempting to think that I could just "pick out a number that I like" from a table, but it is understandable that this just isn't the case. The brief bit of metallurgy education that I received in college has helped me to navigate the various information that I've found on this subject, but unfortunately the theoretical bias of my coursework never pointed out the complexities and nuances of actually specifying a material for a given design. I suppose that's what real life experience is for! I will say that it is much more satisfying to dig your mind into something and try to fully comprehend it rather than just picking a number a taking the table's word for it.
04/04/2011 8:28 AM
How do you know that the material is 316 stainless?
Any supplier of steel will have test reports for their material.
Check the ASTM specification for the grade to obtain minimum yields.
Good Answers: 119
04/04/2011 3:30 PM
We in the aviation industry work to the material specs in MMPDS, maintained by the FAA (formerly Mil-HDBK-5).
Beware: it costs ~$700US, and is agonizing to work with. But, then, if the FAA is managing it, it's never gonna be easy.
Hooker
Register to Reply 18 comments
akouvolo (1); cingold (1); cwarner7_11 (1); Ed Weldon (2); Hooker (1); lyn (1); Milo (5); RVZ717 (2); Tritium17.6 (3); welderman (1)
