Previous in Forum: Yield Strength of 316 SS   Next in Forum: Motor Sizing for Rack and Pinion
ASME II materials question
03/31/2011 7:36 PM
I require a stainless steel tube (SA-213) that has a thick wall and I could not find a supplier for it. I was told that instead I should get a stainless steel bar and machine it. The allowable stress values in ASME II are based on the material form. If I used allowable stress values for a tube in my wall thickness calculations and, I will end up using a tube that is not made to SA-213, but machined out of a bar, is that allowed under ASME? Any suggestions as to what I can do about it?
Thanks!
Good Answers: 101
Re: ASME II materials question
03/31/2011 7:43 PM
Start by telling us the required tube size, wall thickness, length, and design pressure. I find it very hard to believe that there is not an off the shelf solution for you.
04/04/2011 12:49 AM
Hello,
Please, read the reply to Mukesh's post for more detail. Thanks.
OP
04/01/2011 12:42 PM
You have decided your self. We are not aware of your requirement then how any body will help. Share some critical parameters for submitting our views.
04/04/2011 12:47 AM
Hello Mukesh,
ID=16mm, OD=46mm, wall thickness=15mm, length=2500mm, material=316H (SA-213), pressure=28MPa
Any comments, please?
OP
Anonymous Poster (2); Mukesh0861 (1); RVZ717 (1)
