Previous in Forum: ASME II materials question   Next in Forum: Steel Heat Treat Question
29 comments
Motor Sizing for Rack and Pinion
04/01/2011 6:44 AM
I have a mass (m=140kg) and would like to move this mass horizontally (lets say on 6m I-beam held horizontally). This mass is attatched to the electric motor. The electric motor has a pinion that is to rotate on the rack that is fixed to the I-beam (stationary rack and rotating pinion) such that the mass moves together with the motor. I am going to make sure that the weight is supported by wheels that will be running on the I-beam (no weight will be experienced by rack and pinion combination).
Briefly my question is how I select the motor that is going together with that mass on a rack and pinion? lets say the whole system (mass of the motor and mass m add-up to 200kg). How can I select the motor that moves this mass (200kg) on a stationary rack! Remeber weight is not a problem, I just need to move it horizontally. I think its about mass moment of inertia!
Kind regards
ProHubble
Re: Motor sizing for rack and pinion
04/01/2011 6:50 AM
F = ma. Determine how fast you need to accelerate the total mass of motor, gearbox if any, load, and misc hardware. Then torque = F x pitch radius of pinion. Select motor to satisfy this torque as well the desired final speed.
04/01/2011 7:36 AM
Thank you very much. I think I am on the stage where I can progress. I will come back to you incase I encounter a problem.
04/01/2011 7:06 AM
The motor that turns the restaurant section at the top of the British Telecom Tower in London is of the order of 0.75kW. That's because this large mass turns slowly and is supported on low-friction bearings.
Motor power is torque multiplied by angular velocity divided by efficiency.
Good Answers: 181
04/01/2011 7:51 AM
When was the last time you were up there ?
It been some years for me, think I was 9 or 10 years old.
It was actually on pneumatic tyres.
Good Answers: 15
04/01/2011 7:18 AM
Try browsing through the catalogues of companies that sell motors, gear reducers, etc. Some of them have a section set aside for engineering calculations.
How fast do you want that mass to accelerate and decelarate?
What is the desired speed?
Is the motor AC or DC?
What is the motor RPM?
What is the pitch diameter of the pinion?
downhill slide to 112 (damn memor.)
Good Answers: 15
04/01/2011 8:56 AM
04/05/2011 1:02 PM
I think I will just go for rail and wheel. I am worried about rack and pinion calculations. I just want the motor that will turn to both clockwise and unticlockwise. Which is better between AC and DC in terms of perfomance and cost for this case?
Good Answers: 15
04/05/2011 1:38 PM
Not sure. It's been several years (10+) since I've worked on anything similar.
AC power is generally available. That would be my first choice.
Re: Motor Sizing for Rack and Pinion
04/01/2011 8:01 AM
Another thing you must consider is the load friction - can you make any estimate? What kind of bearings will you be using? What are the rolling surfaces (I-beam "track" and the wheels) like?
04/01/2011 8:37 AM
JohnDG, I am designing exactly what your talking about (electric beam trolley). If you copy and paste the website in bracket (http://www.google.co.za/imgres?imgurl=http://www.steelerectortools.com/i//Beam_Trolley_Dimensions.jpg&imgrefurl=http://www.steelerectortools.com/catalog/item/3974986/3727370.htm&usg=__MK2TWrZFoYSXUbJj_a-GCfD3uTI=&h=438&w=599&sz=32&hl=en&start=206&zoom=1&tbnid=HfzuO15CfWXR4M:&tbnh=151&tbnw=253&ei=T8SVTZLkC4_g4AaSntWmDA&prev=/images%3Fq%3Delectric%2Bbeam%2Btrolley%26hl%3Den%26sa%3DX%26biw%3D1007%26bih%3D678%26tbs%3Disch:1&itbs=1&iact=rc&dur=78&oei=HMSVTb3CIcqAOv-V7J0H&page=17&ndsp=13&ved=1t:429,r:0,s:206&tx=150&ty=119) you will see a simple drawing. Imagine just attaching rack under the I-beam and then attatch the motor to the moving trolley with a pinion from that motor running on the rack together with the load that can be attached to the trolley.
04/01/2011 8:50 AM
Are the "tracks" just rough metal (as supplied) or have they been finished at all?
Good Answers: 183
04/01/2011 1:44 PM
You need a special support for the motor since the distance between its shaft and the rack can be variable. You risk an edge effect and correlated problems if the gear comes too deep into the rack. In such situations the motor is mounted on a compliant element so that if radial load becomes too important the motor can move outwards.
04/04/2011 3:54 AM
hi prohubble,
i seen your drawing and its correct, however installing a geared motor directly on one of the rollers is quite more simple than the installation of rack gear
mike
arang na gwapa sa surigao
04/04/2011 2:55 AM
Hi,
I think the best way to drive your mass will be by wheel and rail, it is much easier to design and not so complicated.
04/04/2011 4:36 AM
Ok thanks, after trying to make calculations I also realised that I have to change my design a bit. I am going to try wheel and rail as you suggest.
04/04/2011 4:42 AM
hi,
Yes because here in our plant we do not use rack and pinion due to its complex design however if you use wheel and rail as the calculation will be as easy as 1,2,3..
Mike.
04/04/2011 6:10 AM
So you mean I can just install the motor in such a way that the motor shaft turns with the same speed as the wheel that will be attached to it?
04/04/2011 8:32 PM
hi,
strictly speaking if you say motor, it cant be done due to the speed but if you use geared motor, let see for example with an output speed of 60 rpm, then you can mount it directly...
mike
04/04/2011 6:15 AM
So you mean I can just install a motor in such a way that the motor shaft turns with the same speed with wheels? meaning the motor shaft is going straight to the wheel and turns together with that wheel?
04/04/2011 9:19 PM
Refer to the attached picture for your reference
04/05/2011 12:54 PM
Ok thanks. Is it not critical that I balance the extra weight of the motor? For instance by using another motor on the right side so that they can balance each other.
04/05/2011 1:00 PM
Just use a dead weight to balance it - don't need another motor.
04/06/2011 9:37 PM
hi,
Sorry for the late reply, yes johnDG is correct just use a dead weight.
Mike
04/14/2011 11:58 AM
Please consider the drawing you have sent to me and check my calculations for the selection of the motor to drive the trolley
Power calculation
V = 0.6 m/s (constant horizontal speed of the trolley on the beam)
M = 400kg (total mass to be driven by the motor at speed v = 0.6 m/s)
a = 1.5 m/s^2 (acceleration for the trolley to reach the speed v = 0.6 m/s)
0.03 (coefficient of rolling friction for the surfaces of the wheel and I-beam that are in contact)
g = 9.81 m/s^2 (acceleration due to gravity)
F = (ma + 0.03mg) = (400*1.5 +0.03 * 400 *9.81) = 717.72 N (force required)
P = F * V = (ma + 0.3mg) * V = 717.72 * 0.6 = 430.6 watts = 0.43kW
Torque calculations
N = 75 rpm (shaft output rotational speed of the geared motor attached to the wheel)
r = 0.075 m (radius of the wheel to be driven by 75rpm geared motor)
T = p / (rotational speed in rad per second) = 430.6 / (75 * 2 * pi /60) = 7.85 Nm
From (http://www.insanehydraulics.com/letstalk/powerfactor_ficheiros/motor_current.pdf) the standard motor of power just above 0.43kW is 0.56 kW AC 3-phase motor or 0.56kW AC single-
04/14/2011 11:35 PM
hi,
your computations are correct however you missed two factors, the Electrical Eff. of the motor and the Mechanical Efficiency of your Gear box.... hence your final equation should be:
Power (geared Motor) = 0.43 KW/ (0.85 x .85)
Geared Motor Power Will Be= 0.59 KW but based on your attached data the next higher kw rating is 0.746 Kw so its up to you to decide..
by the way, if you service crane is not 24 hours operational then you can use the 0.56 KW motor but if it is operating continuously then I suggest that you will use the 0.746 KW(0.75 KW).
for the phase, of course you should 3 phase for forward and reverse operation...
good luck,
Mike
04/17/2011 7:32 AM
Kind regards
Prohubble
05/09/2011 6:33 AM
Hi,
May I ask for the websites or catalogues that can help me with design calculations for the whole jib crane please. My I-beam trolley has to move on this jib crane. Anything that can help me to see if I am on the right track.
04/26/2013 4:32 AM
Does anyone know whether to consider the coefficient of rolling friction for rack and pinion drive or not??? im also designing a same kind of trolley which is driven by rack and pinion...pls help me
04/29/2013 1:07 AM
hello,
try this site, maybe it will help for your calculation....
http://www.atlantadrives.com/pdf/ads_racksel.pdf
Register to Reply 29 comments
ddk (3); JohnDG (3); johnnyvijay (1); nick name (1); ProHubble (10); PWSlack (1); Russian_1979 (8); TonyS (1); Tornado (1)
