Previous in Forum: Computer Desk is a Pain in the Neck   Next in Forum: Best pH Controller in Market
19 comments
Results and Data from Simple Cooling System Prototype
03/31/2011 9:47 PM
The last thread was getting pretty crowded so I'll start another, as I'm interested to know what you guys make of this.
This info and some photos of the setup can be found at http://urbangreenhouse.blogspot.com
I did two basic experiments.
1.
Filled the 20 litre drum (30 cm tall, deepest point 1.1 m, shallowest 80 cm, in dry sand over sandstone) with hot water. This was in the form of 3 x 7 litres bought to boiling on the stove and poured into the tank through the connector hose. Should've measured the water temp at start and end of filling (took a minute or two to get it through the funnel) but I'm going to assume it was about 90 C. The ground temp was around 24.5 C.
So:
First 7 L volume at 9.40 am, second at 9.57, third at 10.12. Measured tank temp at 10.15 and was 77 C. This is a total of just on 5.75 mega joules above the ground temp.
Full data:
time water temp (C)
10:15 77
10:30 74
10:50 70
11:05 67
11:20 65
11:30 64
11:45 63
12:00 60
12:15 59
12:35 57
12:45 56
13:00 56
13:40 53
14:00 52
14:30 50
15:00 48
15:35 46
16:35 43
17:00 43
17:45 41
18:45 39
20:00 38
21:00 36
23:20 34
00:15 33
08:20 29
11:25 28
13:15 28
14:00 28
16:00 27
17:15 27
18:30 27
23:35 26
08:45 25
And 2:
More relevant to the actual cooling system, I plugged the whole thing together and ran it for about 8 hours. The setup was: air being sucked from the top of the house through about 9 meters of 18mm garden hose into the air pump housing, which was a vacuum cleaner pump and motor inside a tupperware container with the attached electronics.
This meant the air was passed over the motor itself, which added a lot of heat to it. Dumb for a proper installation, but good for fully testing the system.
Air flow was about 2 litres / second, in that it took 20 seconds to fill a 40 litre bag.
The air then passed through 3 m of hose, bubbled through about 30 cm vertical of water, and exited into the house through another 3 meters hose.
............Air In....Air Out...Air House
11:15.......50......24...........30
11:30.......52......24.5........30
12:05.......54......24.5........31
12:40.......53.5....24..........32
13:25.......55.5....24..........29
14:40.......50......24.5........28
15:20.......49......24.5........27
16:20.......46......25...........26
17:05.......48......24.5........26
19:10.......45.5....24.5........25
'Air in' being the temp coming out of the hose from the pump, ie just before it enters the tank. Pretty high due to the motor, the general air temp was about 34-36.
Air out is the air coming directly out of the tank.
Air house is the what came out into the house. At about 13:00 I wrapped the whole last length of hose in insulant and moved it out of the sun. I was surprised by how much heat the air picked up through only a couple meters of rubber hose, but there you go.
So I guess the two most striking things are that even with a fairly basic interface between the air and water (vague attempt at a diffuser, not really) the air dropped all it's heat, even at 55 C.
And that even with only 20 litres of water, which was only ever meant as a quick test, the water temp didn't really come up over the ground temp. True that 2 litres of air per second isn't much (I could've turned the motor up a lot more, but didn't want to 'splode it) but at an average of 50 C, the air was twice the temp above 24 that it would probably usually be running, so is therefor the same energy as 37 C at 4 litres per second, which is quick enough to replace 50 cubic metes of air in about 3.5 hours.
Which aint bad, frankly. It aint bad at all...
Thoughts?
Good Answers: 213
Re: Results and Data from Simple Cooling System Prototype
04/02/2011 12:32 AM
I suspect you are going to find that the efficacy of the system will decrease when you are working at more "normal" temperatures. Heat transfer is going to depend on the temperature difference between the fluid and the heat sink. Notice how your curve in the first graph tends to flatten out as temperatures decline. One thing that may help might be more consideration over your diffuser arrangement. If you can get smaller air bubbles, you increase the heat transfer surface area. With regards to getting the heat transferred from the water to the ground- I am not sure your test procedure really defines your actual operating constraints...What would be nice would be some numbers on water temperature, both day and night. You obviously have not exceeded your heat capacity in the water tank yet, but how does the water temperature build up over the day? Does it come back down at night?
I like your air pump- but I would have done it with duct tape...
04/06/2011 11:47 PM
Yes, but if the temperature gradient was insufficient to push the heat through there'd be a rise of at least a couple of degrees. Here the air is coming out bang on the ground temp of 24.5
I thought this would be more of a concern, but am actually surprised how well my initial attempt seems to have worked. Like I say, the air was coming out at the water/ground temp, even when it was going in at up to 55 C, so I think I might even be able to back off it a little, and maybe have no diffuser at all and a shallower inlet, which would be great for reducing resistance to the air flow.
At the time of this test, 24.5 C, no daily variation.
http://urbangreenhouse.blogspot.com/2011/01/ground-temperature-data.html
It didn't during the 8 hours I ran this test, and you probably wouldn't run it longer than that in a day. If there was buildup during the day the rate of loss overnight still remains to be seen, and would be entirely dependant on your soil type.
Duct tape would've been better, yes, as the stuff I used was kind of stretchy. But I ran out. Hence the string.
Science!
Good Answers: 213
04/02/2011 12:33 AM
PS. It is great to see someone post actual test data here...
Good Answers: 75
04/07/2011 3:05 AM
This is a repost from the old thread but since it's related to the test data I thought it would be prudent to post it in this thread too.
The results of the first experiment are pretty much what I would have expected to see and if you know the surface area of the water that was in contact with the walls of the container you should be able to work out the thermal conductivity of the system which you would then be able to use to calculate how much and fast the heat could be dumped into the surrounding earth.
However, in experiment 2 there is a major problem and that is the humidity of the air returning to the house from the water container. What you have there is a pretty good evaporative cooler rather than heat exchanger and you need to take into account the enthalpy of the air going into the container with the enthalpy of the air coming out to get an idea of the amount of energy being transferred. Otherwise you are not comparing apples with apples.
What happens when you bubble hot air through cold water is the water evaporates into the air and cools it due to the latent heat of vaporization but raises the relative humidity of the air in the process. In a closed system like yours this is ultimately going to cause a problem because the air will soon become saturated with water and you will end up with much less heat transfer than in your experiment .
Actually thinking about it evaporation of the water into the air as it's bubbled through is going to be a major problem. In the beginning you will get what appears to be really effective cooling, that's till the air that is being recycled becomes saturated with water and then and only then will you start transferring heat into the water. This is going to be a big problem because plants need to be able to evaporate water from their leaves so while they like humid climates they can't cope with a climate that has a relative humidity of 100% all the time. You will also have problem with condensation overnight when the outside air temperature drops, not to mention building the perfect environment for the growth of moulds and or bacteria.
However, I think there is a solution and that something akin to the way a boiler or heat exchanger works. Basically you have container of water that has lots of pipes running through it. You then blow the air through these pipes and transfer the heat energy to the water which is then both temporarily stored in the water and transferred to the surrounding earth whenever the soil temperature is lower than the water temperature. This way the water never comes in direct contact with the air so you don't have a problem with evaporation. In a low pressure system like this copper would be the best material to construct both the heat exchanger and buried container because it has both a very good thermal conductivity and resistance to corrosion
It's going to make the system somewhat more complex and it may be simpler to just lay a grid of polly pipes in the ground that you blow the air through directly, but if you have the air coming into direct contact with the water you are going to have evaporation and while that will cool the air initially in a closed system it is going to have problems with air that is saturated with water.
I must apologize for not thinking of this earlier as it's going to have a major effect on the design of your system, but I still think experiment 1 shows that you have the basics of a workable system. You're just going to have to work out a different way of transferring the energy in the air to the water as bubbling it through isn't going to work.
Good Answers: 75
04/07/2011 4:50 AM
"Keep in mind that the 50-55 C air was a result of the motor, and in a real setting you'd probably be looking about mid thirties at most, and cooling during the day as the system takes effect."
This is true but given the output temperature ranges through only 1°C while the input temperature varies through 9.5°C tend to lead me to believe that the cooling effect you are seeing is primarily due to the evaporation of the water rather than the transfer of heat into the water.
Keep in mind the most important factor here is not the temperature of the air but the enthalpy which is a measure of the total energy content of the air. If you have air coming out that is at 90% humidity which is I suspect the case then you are getting very little change in the enthalpy of the air and therefore little transfer of the heat into the water.
Unfortunately there is no way to get around this, but you will have to redo experiment 2 except this time monitoring the following:
  • Air input temperature
  • Air input dew point
  • Air output temperature
  • Air output dew point
  • Water temperature
  • Air flow rate
  • Water volume
I know this sounds like a lot of things to monitor but they all have a part to play and with them and a psychrometric chart you will be able to work out how much energy is being transferred into the water and how much of the cooling is due to evaporation.
Mind you, evaporative cooling isn't all that bad as it is a very efficient way of cooling things down, it just requires you to vent the hot dry air and replace it with the cool moist air. If you have ever seen the greenhouses north of Adelaide where they grow things like tomatoes and roses year round you will find that they use evaporative cooling systems that vent the hot air straight into the atmosphere and replace it with cool humid air.
Getting back to experiment 1, which by the way I believe was a resounding success, if you can give me the exact dimensions of the container then I can calculate the coefficient of thermal conductivity that you got which you can then use when you scale everything up to calculate how much and fast you will be able to dump energy into the surrounding earth.
Keep in mind, I still think you have the basis of a workable system, it's just going to be slightly more complex that you first thought, but then that's pretty much what always happens whenever you start designing something from scratch.
04/08/2011 7:05 PM
Just a quick reply til I get a chance to respond properly; the tank was a cylinder of diameter about 27 cm and about 35 cm high. This gives a total surface of 4100 cm^2.
It was thin steel, the soil was dry unpacked sand on a sandstone base and the area was in shade throughout the day.
Good Answers: 75
04/10/2011 6:29 AM
G'day folks
Without going into the technicalities too deeply I took the figures from experiment 1 and worked out how much energy in joules was being lost to the soil over the time frame of the experiment.
Now since the rate of energy loss is proportional to the temperature difference between the water and the soil I corrected for that and then divided the result by the surface area of the water that was in contact with the soil.
As expected there was quiet a variation over the period of the experiment but the median rate turned out to be 9.97 ± 5.67 Wm-2°K-1.
So what does that mean, well it means that you can expect to radiate about 10 watts of power into the surrounding soil per square metre of surface area per degree of temperature difference between the soil and the water in the radiating container.
There are two things to look at here and the first is the m-2 factor. It means per square metre so the larger the surface area the greater the power (energy per unit of time) you can radiate into the soil and the better your system will work.
The other factor to look at is the K-1. This means per degree Kelvin (Celsius) and again it means that the larger the temperature differential between the water and the soil the greater the power being radiated into the soil.
So, in the real world I would say that if you allowed for a cooling power from your system of 10 Wm-2°K-1 you wouldn't be too far off the mark.
However, and this is a really big however, there is no allowance here for the soil heating up which is going to decrease your temperature differential and therefore reduce the amount of energy being radiated into the surrounding soil.
If this all sounds confusing please don't hesitate to ask and I will try and elaborate as best I can.
04/16/2011 3:01 AM
> while the input temperature varies through 9.5°C tend to lead me to believe that the cooling effect you are seeing is > primarily due to the evaporation of the water rather than the transfer of heat into the water.
Possibly, or that the heat is being transmitted into the ground faster than it's building up in the water.
I had a thought about evaporation, in that it'd be limited to how much energy is in the air. 1 litre, say, of air at 55 C would have a mass of of 1.28 grams and 38.4 Joules more than at 25 C. This is enough energy to evaporate about 0.02 ml of water, which would create 34 ml of water vapour. I frankly can't figure out how to calculate how much of an increase in relative humidity this would be in 25 C air, but in absolute terms it represents 3.4% of the air volume.
And this doesn't take into account the energy required to raise the temperature of the water or how much vapour would recondense.
And at 37 C this would be halved.
> you can expect to radiate about 10 watts of power into the surrounding soil per square metre of surface area per degree of > temperature difference between the soil and the water in the radiating container.
Which at about .4 square meters for the tank would be 4 joules per second per Kelvin, and according to my previous energy calculation, at 2 l per second there should be about 40 joules per second coming in.
So either the water is 10 degress hotter than the soil, which it wasn't, or the energy is leaving in some other fashion, which I guess is the basis of your increased humidity hypothesis.
Hmmm...
If that happened I'd just use a bigger water container, til it stopped.
Thanks for taking the time to work all this out.
Good Answers: 75
04/25/2011 9:07 AM
Sorry for the delay in replying, but I've been literally buried in paperwork trying to sort out my wife's filing system for her business. To date it has consisted of about 20 piles of paper that to the best of my knowledge and ability has no methodology, organization or system that can be comprehended by the average male.
Anyway, back to the cooling system, one of the things that I took into account when I did the calculations and forgot to mention is that I did not include the surface area of the top of the container in the radiators area. This is because there would need to be an airspace there and air is a fairly good insulator so even a centimetre of air would pretty much prevent any energy from radiating upwards through the roof of the buried drum.
I'm still concerned about the evaporation rate though as your system works in a way that is analogous to an evaporative cooling system and that can dramatically reduce the temperature of the air at the payoff of increasing the moisture content and relative humidity. Back when I lived in Adelaide we had an evaporative cooler in our house that on 40°C days had no trouble keeping the inside temperature in the twenties. However, evaporative cooling systems are total wastage systems which means that they displace the hot dry air by blowing it out open doors, windows or vents and replacing it with cooler but more humid air that has been drawn from outside and passed over a filter that has water cascading over it.
Which brings me to your system, it's a closed system and therefore doesn't have any way of reducing the humidity by wasting air to the outside.
Having said that, I still think experiment 1 and the 10 Wm-2°K-1 will give you a workable system provided you find some way of preventing the water from evaporating and ultimately saturating the air.
The best way to find out what's happening would be to as I recommended earlier and redo experiment 2 but this time recording the wet bulb temperatures as well as the dry bulb temperatures of the air going into and out of the heat exchanging system. This will then allow you to calculate the enthalpy which is the true energy content of the air going into and then out of your system and give you a true reading of how much energy is being transferred into the water.
On the other hand!
Given the data you posted in Experiment 2 and the specific heat of air being 1.297 Jl-1°K-1 I calculated that:
  • Total energy removed from the air was approximately 1.826 MJ
Now given that the latent heat of vaporization of water is approximately 2.257 MJl-1 then the amount of energy transferred from the air could have been lost by evaporating:
  • 1.826 MJ ÷ 2.257 MJl-1 = 0.809 litres
which means that all the energy you pumped into the 20 litres could have been taken up by evaporating about 809 ml or 4% of the of water and not increasing the water temperature at all.
So the question then becomes how much water did you loose from your 20 litre container?
My guess would be that you would have lost between 400 and 600 ml of water which would mean that somewhere around a third to a half of the energy was radiated into the water while the rest was taken up with converting the water liquid into water vapour.
Given that your tank was 30 cm tall and contained 20 litres means that each mm of water drop represents about 67 ml and that means if all the energy were lost by evaporative cooling then the level would have fallen by just over 12 mm which isn't much at all and would be easy to overlook.
If you didn't check how much water was lost in experiment 2 then repeating it and calculating as accurately as possible how much water was lost would confirm how much energy was going into the water and how much was being lost due to evaporation.
However, keep in mind the latent heat of vaporization of water is 2.257 kJ ml-1 which is a lot when compared to the 1.297 J l-1°K-1 that the air contains and means that it doesn't take much water to sink energy from a lot of air so you really need to calculate the amount of water being lost as accurately as possible, preferably to the millilitre.
If you can redo experiment 2 but this time keep track of the water loss then post the results here I would be happy to redo the calculations and work out how much energy was going which way.
Regards,
masu
Good Answers: 74
04/25/2011 5:45 PM
That was well written Masu, GA.
Not only are you sorting out your better half's paperwork work but have reorientated, sorted a few things for me as well.
With such little investment in hardware and set up everybody should have one. I suppose it could be scaled up easily. The distribution of the air and the pump will chew a bit of energy but in comparison to other methods of cooling it has merits.
In combination with something I am working on I would surely introduce it to any future house I would build.
Thanks to the original poster for putting this up, very interesting, Ky.
The Twain Has Met
Good Answers: 213
04/25/2011 6:35 PM
Assuming Masu's analysis is correct (and I have no reason to doubt that it is, since it is consistent with my own experiences) this is an evaporative cooling system. If I still lived in the desert, I would consider nothing but a swamp cooler- low energy consumption, contiually refresshing the air, etc. However, the efficacy is going to be significantly reduced in a tropical climate where normal ambient humidity is on the order of 70-90%- I don't think they would work too well on Magnetic Island, or here in Panama...
Good Answers: 74
04/25/2011 7:02 PM
Hi Charlie
Hope all is well in your neck of the woods.
I was told by all and sundry that this would not work in the tropics but it worked and never mind the humidity. I was the inventor, manufacturer and distributor 20 years ago. Sold the idea and they thought to use different (cheaper) materials and altered some other designs. Very sad for me because I had done so much work to get it to that stage and receiving royalties was out of the question.
Death by bean counter, Ky.
The Twain Has Met
Good Answers: 213
04/25/2011 7:21 PM
Actually, in this part of the tropics, we install pool HEATERS, not coolers! Solar works very well for that...
04/25/2011 10:49 PM
Thanks again for the excellent feedback.
I'm probably not going to get to do too much more on this in the short term; I'm just starting in on the first solarflower workshop, while simultaneously building the greenhouse prototype and somehow getting the website up. Also am in New Zealand, where cooling of growing spaces and homes isn't such an issue.
At some point tho I will test this humidification issue, Masu your idea of measuring water volume loss is a good one and I'll also see if I can get use of a RH meter or similar.
The prototype is back in Australia keeping my mum's house nice and cool, apparently.
Regarding the pool cooler, how does that work?
Regarding energy use of this system, ideally the air pump would be powered mechanically by a wind turbine, with an electrical backup for low wind periods. I looked briefly into the operating rpm of vacuum cleaner air pumps and horizontal axis wind turbines, I think it should work ok.
Good Answers: 114
04/25/2011 11:42 PM
A nice side draft cooler mounted close to ground level
in conjunction with a tall peak mounted vent will do quite a bit of cooling with just a small water pump to keep the pads wet
The taller the vent the more natural flow
throw in a water treatment block every month or so
I run a similar unit
120 hours of running the blower for 20 bucks a month, the water pump is less than $5 a month
Good Answers: 75
04/26/2011 3:41 AM
I had some further thoughts on the evaporative cooling component in experiment 2 and how to calculate how much of the cooling was due to evaporation.
But first up we need to know a bit about relative and absolute humidity. Absolute humidity is the amount of water dissolved in the air while the relative humidity is a measure of how saturated the water is with water vapour. Now the interesting thing about absolute humidity is that provided you don't have a major weather front go through the absolute humidity remains relatively stable while the relative humidity varies throughout the day as the temperature rises and falls.
So, how does that relate to the experiment I hear you say?
Well, if I knew the temperature and relative humidity sometime during the day that you did your experiment then and that there was no major weather front moving through I could calculate the absolute humidity or water content of the ambient air and from there calculate how much more water the air could absorb as it went through your simple heat exchanger.
Now you mentioned that you lived in the Nelson Bay region of NSW Australia and in your post on 30th March that contained the experimental results you said that you did the experiment about a week earlier. So, I went to the Australian Bureau of Meteorology's web site and looked up the records for Nelson Bay in March 2011 and looked at the readings about a week before the 30th.
Now I was hoping that the weather around then was stable because I could then deduce the absolute humidity or moisture content of the air, but guess what? Yes you guessed it, a bloody great front went through the region some time on the 23rd March and the relative humidity and temperatures varied dramatically over the period in question.
But, we're not totally snafued yet as if you can remember the date or even the day of the week on which you did the experiment I can use the BoM records for the exact day to calculate the moisture content of the ambient air and from there figure out how much the evaporative cooling effect was.
So it all comes back to you at the moment, can you remember the date or day of the week that you did your experiments?
04/26/2011 9:00 PM
You sir, are a legend. I'm just going to put that out there.
re historical humidity data, I was in Fremantle Western Australia at the time, currently I'm in the Nelson Bays area, NZ.
The date was the day I flew out, which (*checks) was the 25th of March. There's a site (I think it's Nine MSN weather) which has data records on this, I'll check into it when I get the chance (madly rushed with giving this solar workshop at the moment).
Keep in mind tho that the air going into the system was tapped off the second storey of the house, so not being from directly outside it may have a different water content...
And I'm pretty sure there were no fronts went over that day.
Good Answers: 75
04/27/2011 6:59 AM
"Keep in mind tho that the air going into the system was tapped off the second storey of the house, so not being from directly outside it may have a different water content..."
You'd be surprized at how constant the water content in the air is provided nothing major happens with the weather pushing a new block of air through like you see with cold and warm fronts moving through.
While the relative humidity in the roof would be much lower than in the atmosphere this is primarily due to the higher temperature and the moisture content would be fairly close to that in the atmosphere. It might be a little dryer due to it being trapped, but your experiment removed some 57 m3 of air from the roof cavity which would have been replaced with the outside air.
So, for the purposes of your experiment using the moisture content of the outside air would more than likely be close enough, at least for a first analysis anyway.
In the meantime I'll see if I can get the records for Freemantle for the period around the 24th March and see what pops up.
Good Answers: 74
04/26/2011 4:27 PM
Hi saf
Try this at home.
Take some hot water and spray it through a fine nozzle, like a child's water pistol, check the temperature at the outlet and a meter and then 2m away from the outlet. The water will cool down while traveling through the air. You can have the same experience when you take a shower. You will notice that the water leaving the spout is hotter than the water that traveled all the way to your feet.
The rest is history, Ky.
The Twain Has Met
Register to Reply 19 comments
cwarner7_11 (4); Garthh (1); ky (3); masu (6); sugarandfat (5)
You might be interested in: Air Hose and Air Duct Hose, Hose Crimpers, Hose Reels
