i am a newbie in the substation maintenance indstry. one of my problem is that the time i inspected one of our substations, the station battery charger has gotten off from its normal operation. it had already damaged all the batteries it supplied. the station battery charger supplies 10 units of batteries having 12v rating. the charger has a 240vac input supply and output of 125vdc/30a from its plate. but as of now, it is having an output of 200vdc which is way off from its normal operation. the charger also supplies the closing and tripping coil of the 69kv sf6 circuit breaker as well as the protective relay for the circuit breaker
what can i do about this? what is the problem that might have caused the station charger to malfunction? can this affect the normal operation of the circuit breaker and the protective relay?
