Previous in Forum: Omniscientific Conscentious Science!   Next in Forum: ESDS Rated Vacuum
8 comments
Motor Smoking
04/04/2011 10:09 AM
smoking motor after runung for a short time.
Re: motor smoking
04/04/2011 10:13 AM
....means overload trip device not correctly set.
Re: motor smoking
04/15/2011 9:41 AM
thanks
Re: motor smoking
04/04/2011 10:24 AM
Smoking Doorman after reading CR4 for a short time.
Re: motor smoking
05/02/2011 4:03 PM
Maby we should quit the darn habit Doorman. There's no escape S.M.
Good Answers: 73
Re: Motor Smoking
04/04/2011 10:35 AM
Do you have excessive voltage applied to the motor? Check your wiring and power supply voltage.
Good Answers: 145
Re: Motor Smoking
04/04/2011 10:56 PM
Hmm maybe too much oil or the wrong oil in the 2 stroke mix.
Does the motor keep running or does is sputter and die?
Could also be running too hot and the paint is burning off.
Or the rocker cover is weeping oil and the oil is being burnt off the exhaust manifold.
Trying to run a petrol motor on diesel fuel.
injector pump misaligned and out of tune.
Valve guides are worn.
Shorted turn in the windings.
excessive load for the motor rating.
Motor decided time for smoko as per union rules....
Good Answers: 67
Re: Motor Smoking
04/12/2011 3:37 AM
It is like attempting to solve a problem with several unknowns and without any clue. Basic information is lacking in OP. Also I find OP is indifferent on efforts by experts, may be enjoying it for his stupid question.
Good Answers: 58
Re: Motor Smoking
04/05/2011 8:41 AM
No Coolant/Antifreeze in radiator.
Broken water pump belt.
Radiator fan not coming on.
Pulling too heavy of a load.
No oil in crankcase.
Register to Reply 8 comments
Anonymous Poster (1); Doorman (1); kisembo denis (1); KJK/USA (1); NotUrOrdinaryJoe (1); pritam (1); PWSlack (1); Tobugrynbak (1)
