Previous in Forum: Medium Voltage Cable Insulation Test (Megger)   Next in Forum: Uneven Frequency
Nigeria - Member - New Member
Power Calculation
04/04/2011 11:19 AM
when calculating the actual power of an equipment do you use the input power or output power.
got Jesus
Good Answers: 804
Re: power calculation
04/04/2011 11:25 AM
it depends on what you mean by "actual power". Do you want to know what the machine is using, or do you want to know how much it is putting out?
04/05/2011 2:57 AM
i want to know the amout of power it is consuming from the source
got Jesus
04/05/2011 11:37 AM
Re: i want to know the amout of power it is consuming from the source
Then you want the input power.
04/04/2011 11:28 AM
The power required (from the power source) is the input power.
You can gain a measure of efficiency by comparing it to the output power.
The difference is (waste) heat.
Considering an audio amplifier for a minute, if you need a certain amount of power to drive say a loudspeaker at a certain level of loudness, you need to consider the output power from the amplifier.
To know how much power the amplifier will need from the power source to develop that level of output power, you need to consider the input power to the amplifier.
Good Answers: 53
04/04/2011 11:40 AM
That depend on what I want to calculate,
If you want to know, if a machine is sufficient enough to run a given load then you need to calculate output power, If you want to know if a machine can be driven on a given source then you need to calculate input power.
Good Answers: 164
04/04/2011 11:43 AM
i dare say you must specify the input power. If that much power is not input, the machine cannot deliver the so called 'output power' can it ?
Register to Reply 6 comments
AKINOLA (1); JRaef (1); kvsridhar (1); rakesh_semwal (1); rhkramer (2)
