Previous in Forum: Pipeline Wall Thinning Formulae?   Next in Forum: Weldolet-MSS SP 97
Coating - Airless Spray
04/04/2011 3:27 PM
in AIRLESS SPRAY MACHINES 68:1 while using 2 hoses,
one hose with 417 nozzle orifice tip and the other with 217 . will there be any variation in the output pressure .
Re: Coating - Airless Spray
04/04/2011 8:49 PM
At the pump or at the nozzles?
04/05/2011 2:12 PM
at the nozzle
No Pain No Gain
04/05/2011 7:29 AM
Assuming your machine can keep up with two guns, you should be fine.
One sure fire way to know for sure, would be to hook it up and try it.
With an airless machine, there is always a variation in output pressure at the gun tip, and the pressure goes up and down within the lines as the machine pumps. The question is, will it interfere with the proper atomization of the paint?
Good Answers: 21
04/05/2011 9:43 AM
We do this all of the time on the one line. In order to have good control you will need to install a separate material regulator on each on the different guns using a different dip size. You then can adjust the fluid pressure to meet the needs of the tips properly. That assumes your pumping system is sized correctly.
charan singh (1); fixitorelse (1); kramarat (1); lyn (1)
