Previous in Forum: Process control instrumentation technology problem   Next in Forum: Power Transformer Breather, Silica Gel
Rectifier Transformer
04/05/2011 1:13 PM
Aslam O Allkum,
Dears,
I am facing a problem with rectifier transformer, A transformer trip with oil level low alarm. when we checked the transformer the air is built up and the alarm came ,we realized the air then oil level alarm rectified and level is ok. but problem occur again after 10~15 min.we also changed the oil with new one the oil result is 38kv.
Transformer Specification is as under,
Type: RHT Mono Phase
IP: 65
SUPPLY: 400V
ULn: 403 amP
FreQ: 50 Hz
Power : 160.9 kva
Upo : 125 kv
Current: 1.3 amp
P.f : 1.4
Make :Merlin Gerin
Re: Rectifier Transformer
04/05/2011 3:35 PM
Have you checked the oil level alarm? You may be getting a false alarm reading.
04/06/2011 3:44 AM
aoa,
oil level is actually low because there is air cam and oil level deceased when we realized the air then level again full.actually the transformer built a air in oil level tank.
04/06/2011 3:47 PM
I am having a hard time understanding exactly what you are saying, but it sounds like you say you have a seal failure allowing air to enter the transformer and activate the alarm.
Have you checked the transformer seals?
Is this a brand new transformer or an old existing one, if new then it could be a transformer defect, if old then it could be a degraded seal allowing air in.
Good Answers: 11
04/05/2011 8:17 PM
Your description of the problem is very confusing. Your description of the problem could mean that a valve was closed when it should have been open.
The first thing you should do is contact the manufacture. If the power supply is new, then it should be under warranty. Anything that you do could void the warranty.
Did you really change the oil? You should not have, this could void the warranty, and also the symptoms don't indicate it was necessary to do so. Also changing the oil incorrectly can seriously damage the transformer.
Register to Reply 4 comments
Basim (1); Carl Pugh (1); jack of all trades (2)
