Previous in Forum: Aluminum Smelter Dimension   Next in Forum: Experience in Disc Pumps
Bottom Plates
04/07/2011 5:39 AM
specification of bottom plates in storage tanks,def: for bottom plates
Pathfinder Tags: bottom plates
Re: bottom plates
04/07/2011 6:10 AM
1. Bottom plates shall not be located on the sides or tops of tanks.
2. Bottom plates shall be flat unless the tank foundation surface is crooked.
3. Bottom plates be of compatible p-group material for welding to side plates.
4. Bottom plate dimensions shall be at least equal to those of the footprint of side plates resting thereon.
5. I hope I didn't forget anything.
ξ
Anonymous Poster #2
Re: bottom plates
04/07/2011 6:35 AM
A plate at the bottom of the side of the tank, could that be defined as a bottom plate?
Re: bottom plates
04/07/2011 6:59 AM
But wouldn't that violate the spirit of Specification 1, assuming it makes any sense?
--Anonymous Pester #3
Good Answers: 181
Re: bottom plates
04/07/2011 7:18 AM
I think our OP should do his own homework.
Someone asking for a definition is often the trademark of a homework cheat.
Good Answers: 58
Re: Bottom Plates
04/07/2011 8:55 AM
Ah a homework question.
Here is your study excercise "API"
Anonymous Poster (3); KJK/USA (1); TonyS (1)
