Previous in Forum: Derivation of N=120f/P   Next in Forum: Ground Ring Around Roof
BDV of Transformer Oil
04/07/2011 12:40 PM
I am having one confusion about BDV of transformer oil. Usually oil with BDV=28-29 KV is considered ok. But my question is if the transformer rating is 132KV/66KV in that case also BDV value = 29KV is ok or is there any IE rule for BDV of transformer with different KV rating???
Thanks
Re: BDV of transformer oil
04/07/2011 1:09 PM
There's no confusion here. Just use the correct oil. Unless........
is acceptable?
Good Answers: 131
04/07/2011 3:12 PM
According to IEEE Std C57.106-2002, there are different breakdown voltage values depending on the voltage class of the oil-filled equipment. For a 132kV transformer, it falls smack in the middle of the range of 69kV-230kV, for which the minimum BDV is 28kV (ASTM D1816-97, with 1mm electrode gap). I would rate that oil acceptable if I were receiving the test results.
Good Answers: 170
04/08/2011 10:03 AM
BDV OF TRANSFORMER OIL (As per IS 6792:1992)
The oil sample is subjected to a steadily increasing alternating voltage until breakdown occurs in a BDV test kit. The breakdown voltage is the voltage reached at the time of the first spark appears between the electrodes. The test is carried out six times on the same cell filling and the electric strength of the oil is the arithmetic means of the six results obtained. The electrodes are mounted on a horizontal axis with a test spacing of 2.5 mm. The value should be:
Electric Strength (BDV)
Vide IS 1866:2000,
30kV - for Voltages upto 72.5kV
40kV - Above 72.5kV upto 170kV
50kV - Above 170kV up to 420kV
04/09/2011 11:44 AM
Dear Guru,
Thanks for providing a good answer.
But on 7th Apr why you have taken my question as a joke?
& replied perfectly on 8th Apr????
Anyway, thanks again
Thanks
Good Answers: 170
04/09/2011 12:02 PM
Dear Sir, Please take a close look. On 7th it was not me, but M. Slack, who had answeredyour query. I answered your query first and only on 8th April. I do not play jokes on people who are sincere to learn.
dhanesh.koshti (1); electricalexpert65 (2); PeterT (1); PWSlack (1)
