Previous in Forum: New Requirements for 'Cool Roof' Coatings   Next in Forum: Sludge Problem After Treamtment of LSFO
Polyelectrolyte
04/08/2011 1:37 AM
Hi all
We are using polyelectrolyte as polymer in our water treatment plant.
I read in an article that polyelectrolyte are used as coagulant aids in water treatment, and the presence of residues of the unreacted monomer may cause concern.
Please provide information whether we can use it or not?
Thanks in advance
Re: Polyelectrolyte
04/08/2011 2:38 AM
Yes, polyelectrolytes are sometimes used as coagulants for water treatment.
For your SPECIFIC case, you should consult with your supplier regarding the SPECIFIC poly that you are using and the likely problems that unreacted poly might create.
There are many different poly mixes depending on the material to be coagulated. (Our potable water treatment blend is designed to match the algae/coloid nature of our feedwater while our effluent treatment plants use a totally different blend.)
Also, the poly is not cheap.
Careful control over reaction time, mixing, temperatures, contamination levels and so on are essential. (Though most modern plants have feedback techniques to monitor the poly levels, maintain at minimum and add when the coagulant material becomes too "thin". This strategy means that minimum quantities are used and unreacted poly is not released.)
Re: Polyelectrolyte
04/08/2011 6:46 AM
Hi Engineer
Thank you for your reply
Is there any techniques to find the unreacted poly in water. I am mechanical in discipline. So I can't understand the details provided in internet.
Thanks in advance
Re: Polyelectrolyte
04/13/2011 9:17 AM
As #1, talk to the supplier and obtain one that is safe for use on potable water.
Good Answers: 101
Re: Polyelectrolyte
04/08/2011 3:55 AM
Polyelectrolytes are flocculants. They help bind the sludge together.
Re: Polyelectrolyte
04/17/2011 5:42 PM
Sorry for delay, been off line for a week.
Contact the supplier for specific details relating to your poly. (The net is great for general searching, but SPECIFIC DETAIL from the suipplier is necessary in this case.)
DVader1000 (1); Just an Engineer (2); Natarajan (1); PWSlack (1)
