Previous in Forum: Current Transformer Burden Calculation   Next in Forum: Solar Cell Repair
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Synchronization of Alternator
04/10/2011 11:49 PM
What are the points we should take care of while synchronising an alternator first time to the system? How should we check those points?
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Re: Synchronisation of Alternator to the system
04/11/2011 5:19 AM
Must have the same:
1. Phase sequence
2. Frequency and voltage
Not only that point but in protection, panel should complete with:
1. Over load and over current protection
2. Reverse power protection
Hope this little help you
One system
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
Re: Synchronization of Alternator
04/11/2011 1:04 PM
The MOST important is to check that the voltage is 0 between the alternator and the bus you are going to synchronize it to on ALL 3 PHASES when your scope [or lights] say the alternator is OK to put on line. Biggest mistake is wiring and/or rotation, if it's wrong it will show voltage between the bus. Measure the voltage at the breaker that will put it on line, top to bottom, and all three phases.
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
Register to Reply 2 comments
You might be interested in: Check Valves, Test Points, Access Points
