Previous in Forum: Synchronization of Alternator   Next in Forum: Honeywell CSNA111
Solar Cell Repair
04/11/2011 1:30 AM
Has anyone experience with clear silicone (or similar) sealant to go over a cracked glass solar PV cell surface?
Good Answers: 120
Re: Solar cell repair
04/11/2011 6:59 AM
silicone will adhere, but is it transparent enough?
That said, a minimal amount to fill cracks would likely be acceptable, as long as you fully filled the crack, edge to edge with no gaps for water entry. Clean first, remove any grease and
Per Ardua Ad Astra
06/08/2011 6:27 PM
True. The problem is that the safety glass is crazed all over, hence the only way would be to 'flood' the whole surface with a sealant. Since the damaged 180 watt cell is free to me. it's worth trying.
penttijp
Register to Reply 2 comments
You might be interested in: Solar Water Heaters, Solar Mounts
