Previous in Forum: Solar Cell Repair   Next in Forum: How to Test an IGBT (STGW20NC60VD)
Honeywell CSNA111
04/11/2011 1:47 AM
Respected Members,
Is there any way to test (With Digital Multimeter) Honeywell CSNA111 (Closed Loop Current Sensor) which was mounted on the Board (AC BRUSHLESS MOTOR CONTROLLER) ????
Good Answers: 445
Re: Honeywell CSNA111
04/11/2011 2:56 PM
Short answer- yes. Long answer- you'll have to google on the part number, read the data sheets and figure out how to construct a small test bed that generates a variable test current as well as the appropriate low voltage supply for the DUT, then you can measure the response to the varying current with your DMM.
Hint: http://html.alldatasheet.com/html-pdf/168720/HONEYWELL/CSNA111/486/1/CSNA111.html
You might be interested in: Brushless Motors, DC Motors, Dovetail Slides
