Previous in Forum: Japan nuclear crisis higher level   Next in Forum: Capillary Action ~ Something for Nothing?
10 comments
Need Solenoid Valve
04/12/2011 9:53 AM
Need Solenoid Valve that is similar to this,
http://pneuaire.com/lowwasu34wav.html
In pressure capacities, and power requirements.
BUT!
it needs to be compatable with NH3, which that one is NOT.
Can anyone help me?
Joe
Re: Need Solenoid Valve
04/12/2011 11:05 AM
Interesting challenge. I am familiar with "industrial size" ammonia solenoid valves, quite a bit larger than this. I presume that the plastics and elastomers are the sticking points for this example.
Carbon steel, stainless steel, Teflon®, and neoprene are NH3 compatible; most copper alloys are not. I doubt that a Teflon® body could handle the possible pressures, but am unsure (and might not be available even as a custom design).
This doesn't fully answer your question, but maybe it can be a start. Best of luck. Such a valve would be handy for sending samples to an ammonia detector, for instance. If I can find anything, I'll post further.
04/12/2011 11:15 AM
Thanks Tornado
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
04/12/2011 2:43 PM
OH BOY, working on a balloon to stay in near space. Let us know what ideas you have or point where you are working on it NSS, good luck!
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
04/12/2011 2:50 PM
the valve is the only thing holding me back right now.
Joe
Good Answers: 101
04/12/2011 7:44 PM
Could you rebuild the valve with compatible o-rings/seals? I know we tear apart brand new hydraulic valves/pumps/motors and switch the seals depending on the fluid requirements. Many of the pumps are not offered from the manufacturer to be compatible with some of the fire resistant fluids, but we get seal kits and reseal them to work.
04/12/2011 11:13 PM
That is a possibility.
I know anything like copper based copper, brass etc. is an absolute no no.
But what is good for NH3? and what seal parts are good for it also?
Joe
Good Answers: 123
04/12/2011 10:13 PM
I have 4 companies that come to mind.
1) Ingersoll Rand, ARO division. They make many designs, within these designs, there are many more variations. www.ingersollrandproducts.com
2) Clippard pneumatics is involved with small designs. www.clippard.com
3) Asco red hat valves. They are older than dirt, and seem to cover many variables. www.ascovalve.com
4) Whitey valves, by Swagelok. I have some air operated designs that work with 2500 PSI, and have teflon seals and 316 stainless steel hard parts. www.swagelok.com/products/valves
Good luck.
Bob
04/12/2011 10:39 PM
Hello NSS. Ammonia is still used in commercial refrigeration. You can try the refrigeration control companies like Danfos, Emmerson Climate, Alco, etc (disclaimer). In fact I believe they recently sent a tank of ammonia to the ISS.
Good Luck!
Zero doesn't exist.
04/12/2011 10:48 PM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
dust collector
04/13/2011 3:57 AM
Try
http://www.burkert.co.uk/ENG/Products/MicroFluidics.html
http://www.biochemfluidics.com/?gclid=CP6t1omCmagCFYwjfAodK0Pd2g
Google microsolenoid valves
Tony
Tony Aston
Register to Reply 10 comments
BevnBeerGuy (1); bob c (1); kwcharlie (1); mumuXLS (1); NSS (3); RVZ717 (1); Tony Aston (1); Tornado (1)
