good day
im intrest on learning how to judge if a specific clearnces are good or bad for pump,turbine, centrifugal compressor and reciprecating compressor.
1st when i recived the clearances sheet i got two things the actual readings and the allowable range clearances. if the clearnces are out of the allowable range action should be taken to make it on the allowable range.
this is what i know about clearnces but i want to learn more.. how to read the clearnces.. what means if the gap is big or small and what is the effect... the effect of increasing or decreasing the clearances.. and everything about the clearances...
is there a book or website discuss this issue
best regards
