We are using a Vacon drive on a Gantry Crane, for the travel we are using two speeds 15Hz and 75Hz.When the power is removed from the motor a holding brake is activated which locks the motor.The issue is when it changes speed the loss of power in the transition seems to bring the brakes on.The brake gap is set good ,wondering if there is a setting on the drive that can fix the issue
