Previous in Forum: how to calculate the empty weight of the pressure vessel   Next in Forum: Sudden Opening And Closing Of Ipesv In 250 Mw Steam Turbine
Pull out capacity of Bolts
04/19/2011 10:00 AM
If material and mechanical properties such as diameter and length of a bolt is same. Is there a difference between the Pull out capacity (Say tension) of a regular bolt against a countersunk bolt?
Good Answers: 125
Re: Pull out capacity of Bolts
04/19/2011 1:54 PM
Pull out capacity will be affected by the number of engaged threads. The type of head will only come into play if it is of a different design. I assume your countersunk bolt is the same bolt head, just level with or sunk below the material surface.
04/19/2011 2:30 PM
Thanks for your help. It will definetely help us solve the problem at hand.
