Previous in Forum: Pull out capacity of Bolts   Next in Forum: HVAC
Sudden Opening And Closing Of Ipesv In 250 Mw Steam Turbine
04/20/2011 10:36 AM
LET DISCUSS ONE THING, SUPPOSE 250MW KWU DESIGN STEAM TURBINE. MACHINE IS RUNNING ON FULL LOAD AND SUDDENLY IPESV GETTING CLOSED FOR A MOMENT(SAY 10SEC) AND AGAIN OPENED. OR FREQUENTLY GETTING CLOSE AND OPEN. WHAT WOULD BE THE EFFECT ON TURBINE.
RESULTS HP EXHAUST TEMPERTURE WILL SHOT UP APPROX. 700-800DEG C BUT WHY? WHAT WOULD BE THE EFFECT ON HP TURBINE BLADES?
Pathfinder Tags: steam turbine
Re: Sudden Opening And Closing Of Ipesv In 250 Mw Steam Turbine
04/20/2011 11:48 AM
Please turn off the all-caps key.
What is IPESV (which should be capitalized)? Intermediate pressure .... solenoid valve? What circuit controls this valve that would allow it to be closed momentarily?
04/20/2011 12:10 PM
Thanks for response.
IPESV means intermediate prsessure emergency stop valve.
these are isolating the IP turbine from HRH line.
01/10/2023 7:26 AM
It looks like a fault on the equipment that is operating the <...IPESV...>.
For one thing, it might not be suitable for it to self-reset, for example. Without a Functional Design Specification dosument being to hand it is difficult to comment further.
IP - Definition by AcronymFinder
HRH - Definition by AcronymFinder
It is always a good plan to define abbreviations before using them.
04/20/2011 5:16 PM
What type control system do you have? EHC, MHC. What is the age of the turbine.
If it is an EHC unit you may have a control function that looks for a fault to ground and causes quick closing and reopening of the valves to keep a machine with a loose tie to the system from slipping a pole. Kind of far fetched. but who knows.
Sounds like you need the help of KWU.
If you fail to follow through, you will fail.
01/10/2023 7:28 AM
otha (1); PWSlack (2); satyanmeena (1); Tornado (1)
