Previous in Forum: Sudden Opening And Closing Of Ipesv In 250 Mw Steam Turbine   Next in Forum: High Temperature of Thrust Bearing of Steam Turbine
HVAC
04/20/2011 2:17 PM
Is there a blower to suck smoke out of a saloon, due to heat moisture.
Re: HVAC
04/20/2011 2:22 PM
Do you need it to suck or blow?
What is heat moisture? Is it steam?
Re: HVAC
04/20/2011 4:32 PM
An up-blast exhaust fan sounds like what you need. It mounts on the roof and draws hot/moist air up through the ceiling. Some models can be seen at www.grainger.com.
Good Answers: 19
Re: HVAC
04/25/2011 11:46 PM
What you need is an electronic air cleaner to eliminate smoke from a saloon/room.
Re: HVAC
04/26/2011 12:34 AM
Re: HVAC
04/26/2011 8:09 AM
How will that help "... heat moisture", whatever that is.
Doorman (2); ducon (1); Tornado (2)
