Previous in Forum: HART calibrator   Next in Forum: why we use ground wire
Cross Check of flow rate
04/19/2011 12:33 PM
AOA,
Dears,
i want to cross check flow of methane gas, i have a flow meter which given the value in cubic meter/hour, through a orifice plate but i did not know that they given the correct flow rate.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Re: Cross Check of flow rate
04/21/2011 1:01 AM
Based on machine capacity to calculate the theoretical flow in your system. We used to do that and found the meter is 30% incorrect compared to actual flow.
Otherwise, we need to install the other meter in parallel or in series to the existing one to cross check with each other.
Anything that can go wrong, will go wrong
You might be interested in: Gas Flow Meters, Flow Meters, Turbine Flow Meters
