Previous in Forum: Westinghouse DC Generator   Next in Forum: Voltage vs. Current
How to Find Inductance of Coil..?
04/20/2011 12:13 AM
Good morning friends,
Is it possible to find the Inductance of a coil without using a instruments...? & Why..?
for example: by knowing length, area & specific resistivity we can can calculate resistance..
likewise any formula is there to find Inductance..?
With regards,
Amith Raj...
Good Answers: 164
Re: How to find Inductance of Coil..?
04/20/2011 12:24 AM
04/20/2011 12:49 AM
Thank you sir,
i am not even searched in google.. sorry...
Good Answers: 164
04/20/2011 1:14 AM
No problem, glad to have been of some help.
However, the only trustworthy way i found to get the inductance of an iron-cored coil (used for DC13 tests as per IEC 60947-5-1) was to capture the rise time of the current on an oscilloscope, and knowing the coil's resistance, compute the L from the formula I = Imax * {1-e(-Rt/L)}
Maybe i am a little thick, but i could not get trustworthy readings from even top-of-the-line LCR meters.
Good Answers: 116
Re: How to Find Inductance of Coil..?
04/21/2011 6:50 AM
One thing to note - the inductance formulae in Wikipedia, to which kvs directed you, are all without any core (except air! -which is indistinguishable from vacuum for most engineering magnetism). With a core of magnetic material, inductance depends greatly on the transverse air gaps in the core as well as the core's magnetic permeability. As kvs writes, measuring inductance on a "black box" bridge instrument can give misleading values. They often work at a fixed frequency, well away from 50 Hz (1592 Hz comes to mind) and are OK for air cored and low loss cored inductors. Solenoids and contactor coils usually have conducting housings or deliberate shorting rings - which form shorted turns and make inductance measurements 10 or 100:1 in error.
Register to Reply 4 comments
67model (1); amith (1); kvsridhar (2)
