Previous in Forum: VFDs for Exhaust Fans   Next in Forum: RMU Vs Switchgear
Earthing wire for a motor
04/21/2011 12:37 PM
On what basis the size of the earthing strip or wire is calculated. whether by the full load amps or the source side amps. For eg for a 10HP motor with FLA of 12.5A must be earthed with min how much sized cable.
Re: Earthing wire for a motor
04/21/2011 2:32 PM
In the NEC the equipment grounding conductor is based on the size of the overcurrent device. Check this article and table 250.122 on page 2.
http://www.cable.alcan.com/NR/rdonlyres/19FC4111-742D-47B7-9A28-06DF8AB4023D/0/EquipmentGroundingConductor.pdf
Good Answers: 170
04/25/2011 7:24 AM
The earth conductor must be sized based on the maximum single-phase to ground fault current anticipated at the moto end. This shall include the source impedance, the impedances of the starter components, the connecting cable. But, in a large installation such calculations are laborious. So, there are ready reckoners available - giving the earth conductor sizes for various HP Motors.
Register to Reply 2 comments
