Previous in Forum: Power Factor & Generator...   Next in Forum: Force Current And Force Voltag Analogy
DC Motor
04/23/2011 1:46 AM
i have a doubt..is dc motor a voltage controlled device or a current controlled device???
Good Answers: 181
Re: dc motor
04/23/2011 3:16 AM
Re: dc motor
04/23/2011 6:07 AM
basically DC motor is a voltage controlled device i.e when apply voltage to armature increases, its speed increases.
Good Answers: 181
Re: dc motor
04/23/2011 6:13 AM
So what happens when you increase the field voltage?
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Re: dc motor
04/23/2011 6:51 AM
It can be both depending on the application:
If you want to adjust torque, go for current control.
If you want to adjust speed, go gor voltage control.
Anything that can go wrong, will go wrong
Re: dc motor
04/23/2011 7:01 AM
Dear,
DC Shunt motor is voltage controlled device. By controlling the voltage across the shunt winding, speed of motor varries.
DC Series motor is current controlled device. Even though, we gradually change the voltage across motor terminals, but by change in voltage changes the current in field ( as well as Armature ) winding, changing the torque as well as speed.
DC Series Shunt motor is voltage & current controlled device. Voltage across shunt controls the speed.
Current in series winding controls the torque.
Exploring the Science of Electricity
Good Answers: 130
Re: DC Motor
04/25/2011 11:45 PM
How do you get current to flow?
Register to Reply 6 comments
34point5 (1); harry potter (1); hien.nguyenquoc (1); Signode (1); TonyS (2)
You might be interested in: DC Motor Drives, DC-DC Converter Chips, AC-DC Adapters
