Previous in Forum: Anchoring Threaded Fasteners In Bedrock With Epoxy   Next in Forum: Equipment Price Plus Labor
25 comments
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Skim Coat
04/23/2011 10:21 AM
Anyone in civil world please let me know what is skim coat and its application?
If I use the general external or external paint for my house? Is that kind of skim coat?
Anything that can go wrong, will go wrong
Re: Skim coat
04/23/2011 10:44 AM
A skim coat doesn't apply to paint that I know of.
Skim coat generally applies to some type of filler being used to smooth out minor surface imperfections.
On interior surfaces, a thin coat of sheet rock mud/spackling along a wall joint or to fill nail holes would be referred to as a skim coat.
In automotive work a thin coat of body filler to fill minor imperfections would be referred to as a skim coat.
If you're painting the external walls of your house, a skim coat should not come into play..........unless maybe it's concrete. If you're painting over a new surface that hasn't been painted before, you may need to apply a, "primer", that is designed to adhere to the substrate, before applying the finish coat of paint.
Re: Skim coat
04/23/2011 11:54 AM
Thank you Kramarat,
But it is still not clear by my stupid head. Skim coat is somewhat similar to mastic?
Re: Skim coat
04/23/2011 12:16 PM
The term "skim coat" doesn't really matter. Tell me what it is that you are trying to accomplish and I'll do my best to help you. I do this stuff for a living.
This guy is applying a skim coat to cover imperfections. A light sanding and it will be ready for paint. A picture is worth a thousand words. You probably don't want to do this on an exterior surface.
Re: Skim coat
04/23/2011 12:27 PM
English is my second language so I don't know how to understand "skim coat". As your explanation above and the guy, I could see that "skim coat" same as "mastic" which is kind of powder.
But mastic is more familiar to me than skim coat. But for mastic, we can apply it on interior or exterior wall.
You from USA and you do this stuff for a living, do you see my photo familiar to you? This is mastic made by USA suppliers and other.
Re: Skim coat
04/23/2011 12:41 PM
Yes. Same thing. Mix with water and you have the mastic, which can be used for skim coat. Unless you're just filling very small nail holes or something, I would not recommend using these products outside..................even if the package says you can. It won't last.
Re: Skim coat
04/23/2011 12:48 PM
Oh, thank you.
If it would not last, so what I should use then?
Re: Skim coat
04/24/2011 8:08 AM
Once again, what is it that you want to do?
The products in your picture will most likely, A) separate from the substrate. B) Completely break down if exposed to moisture, if used outside.
There is exterior spackling, (mastic), available, but it is not intended to be applied as a skim coat, only to fill small holes.
Good Answers: 130
Re: Skim coat
04/25/2011 3:42 AM
Frustrating Ay - when you know the stuff and every man and his dog "muddies the water" - some blindly "uninformed"
In my world it's called 'spackle', or spack filler, or in automotive 'spot filler' - but you'd think they'd get the concept.
Never mind, I'll cruise through this and GA all your posts.
'Cause they are (bar one)
Re: Skim coat
04/25/2011 6:48 AM
Not really necessary since all of my answers pretty much just repeat the same thing.............bar one.
Reading the OP's other threads, it looks like he may be trying to write a bid/estimate for a job.............................or something.
Re: Skim coat
04/25/2011 11:30 AM
Well, you are correct in this point that I am trying to comprehend the bid even construction is not my field. If so, you will not mind replying my threads?
Wait a minute, you used to mention that "skim coat" is applied only inside and same as mastic. But why?
Re: Skim coat
04/25/2011 1:31 PM
Kramarat has been giving complete and accurate answers.
You keep saying 'mastic', an implication of an adhesive. That is not correct.
The skim coat can be compared to both the brown coat and finish coat in a stucco wall or ceiling system. The function is to level out a finish, usually in a wall or ceiling. It is not always a finish, or final coat, but an intermediate, to ready a surface for final finish and decorating.
Re: Skim coat
04/25/2011 4:04 PM
"Skim coat" is a process, not a product............see the picture I posted.
What you call "mastic" is a product that can be used for a skim coat.
Nobody here minds answering a question, but this is getting tiring. Please state exactly what it is that you want to accomplish.
I think trying to translate a bid, one phrase at a time, is going to take far longer than either of us, (or anyone), is willing to spend.
Re: Skim coat
04/25/2011 8:48 PM
Sometimes I got a good answer that I say to myself "ok, it can be used". I am sure I sometimes cannot judge it right or wrong but because it simply makes sense. You know, naturally, his name will be noted in my mind because I appreciate the answer and, of course your answer is voted for one or several GAs. And then someone else jumps in putting a new idea and ask me in the other aspect. So, I struggle again after answering that question so as you mention that sticking around is popular here and you (the respected gurus) should not let it happen.
Moreover, why you mention that the "mastic", Ok, I repeat it, that should not be applied for external wall... any reason...and how about the skim coat? Because if you are correct when I state here that skim coat can be applied inside and outside... it would be a disaster. You know...
Re: Skim coat
04/26/2011 6:54 AM
Mix up some of your mastic, apply it to an exterior wall that you don't care about, allow it to go through several wet/dry cycles and you will have your answer. The same thing will happen if it's painted, it will just take longer.
Re: Skim coat
04/25/2011 7:53 AM
And that would be yours!
It would seen that someone just likes to see their name in print. Offering nothing but trash talk. If you don't have anything positive to say it would help us all if you just went back to sleep.
The time has come the Walrus said to speak of many things, of shoes and ships and sealing wax, of cabbages and kings.
Re: Skim coat
04/25/2011 6:02 PM
Hey Michael,
A little off hand remark on a thread that is going absolutely nowhere is pretty common around here. Stick around, you'll soon understand.
Welcome aboard!
Re: Skim coat
04/24/2011 7:10 AM
A skim coat is not a product. In the process of laying 2 or more coats of plaster, stucco, drywall compound etc. the skim coat is usually the final coat.
Re: Skim coat
04/23/2011 12:32 PM
Where'd you find a sober painter on a Saturday afternoon?
Re: Skim coat
04/23/2011 12:49 PM
I'm sure he's passed out and stinking in some darkened room somewhere today.
Re: Skim Coat
04/23/2011 11:41 AM
If one were going to wallpaper a wall, one would skim coat and sand a number of times to achieve total flatness.
Textured walls don't require as much smoothing work prior to painting. the texture hides a lot of flaws.
Re: Skim Coat
04/24/2011 4:12 AM
I think what you are referring to is a watered down 1st coat of paint to seal the surface before building up the coats of paint at full strength,this is normally done on new plaster or render work.
Re: Skim Coat
04/24/2011 7:12 AM
What I mean, is that I want to know what is skim coat? Is there any thing different from Mastic which we are using here.
And, why we jsut can apply skim coat for the internal surface only?
Re: Skim Coat
04/25/2011 3:20 AM
See answer 4 above for skim coat plaster or you can use a skim coat which is then scratched to give a key so additional coats can be applied to build up a finish.
Re: Skim Coat
04/24/2011 7:45 AM
I can only reference your question in terms that relate to concrete preparation or stucco on a house. In concrete applications, when applying a skim coat you are smoothing out imperfections in the concrete surface to give a very smooth texture. First you apply a mastic or concrete link that helps the very thin coating of concrete( fine sand and cement only ) adhere to the surface being smoothed out. It must have a very fine texture as it is a skim or 'surface only' application. On stucco, you do the same process. Coat the underlying material with a link or mastic to help the skim coat to adhere to the surface. In these cases, the mastic or link helps the skim coat adhere to the surface.
Not sure this helps but is the best I can offer.
Re: Skim Coat
04/24/2011 9:17 AM
"What we've got here is failure to communicate". Strother Martin, "Cool Hand Luke". 1976.
Register to Reply 25 comments
34point5 (1); Bazzer Englander (2); Doorman (1); Fredski (1); hien.nguyenquoc (6); kramarat (9); lyn (3); Michael Rock (2)
