Previous in Forum: Procuremnt   Next in Forum: Smiley Faces for MS OFFICE 2007(Help)
How To Use Ghost Back Up On New Computer.
04/24/2011 12:54 AM
Dear Sir,
I am using one industrial computer on our machine with following specification.
OS Windows 2000
BRAND PCQT
CPU 700MHz
RAM 512MB
USB 2 Port
RS232 6 Port (Com 1 & COM2 as default)(For COM3 to COM6 Installed one PCI card)
VGA 1 port
LAN RJ45 1 Port
LPT 1 Port
PS2 For K-Board
PS2 For Mouse
I want to prepare spare computer for my machine & I have one spare computer in my office with following specification. I have norton Ghost bootable backup cd of my existing pc comes when I buy machine. Please tell me can I installed this backup in my spare computer to make spare pc for my machine? Please advice.
Brand Dell
CPU 1GHz
RAM 1Gb
USB 4Port
RS232 COM1 & COM2
LAN RJ45 1 Port
VGA 1 Port
LPT 1 Port
PS2 Not for keyboard
PS2 Not for mouse
Thanks in advance
Always Respect Your Seniors. Best Regards, Ahmad Arshad
Pathfinder Tags: Norton Ghost
Australia - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Electromechanical Engineering - New Member
Re: How To Use Ghost Back Up On New Computer.
04/25/2011 1:45 AM
Hi,
The only time I would use Ghost to restore would be if the PC was identical, like if the harddrive had failed and it was replaced. With yours it is a different brand, a different configuration, and likely different drivers are required to suit. The best way is to install the applications from the install discs/software and set up as a replacement. I have used ghost in the past and it works great for setting up multiple identical PC's or recovering from a harddrive failure.
Tooz.
tooz
Good Answers: 266
04/26/2011 7:35 AM
The biggest issue you may have is the image will have drivers for hardware that is not on the back up computer. It may be easier just to copy what software you need from the one to the other.
Not real familiar with Norton's Ghost as I use Acronis. Have some of the same issues with production equipment. Not only have I made images pending hard disc failure. I have also copied the software the OEM of the equipment placed on the PC. Into folder with the image. Along with a back up file that will have settings and any parameter data that runs the machine.
If you are really concerned about a back up. Just get a replacement hard drive which are cheap. Image it and store it or leave it in the PC unplugged. If it's real critical to operation set up a RAID.
04/27/2011 11:13 PM
Dear Sirs,
Thank you very much for your reply. its mean i can't preform my job on different brand computer due to hardware compatibility.
I will prepare spare hard disk as you said for my existing computer.
tell me one thing, can I prepare my licenced software backup which are installed in existing computers. I those software is corrupt then I will contact to him for software which they will give me in very high cost. is it possible?
Good Answers: 114
04/27/2011 11:38 PM
Insist on support for your legal & registered software, you are entitled to support, don't take no for an answer
Good Answers: 266
04/28/2011 9:00 AM
I have never had any problem getting the software from the OEM of the equipment.
If an image of the hard disc is taken of the software uncorrupted whats the issue. You have a copy. That is also one reason that I made copies of the software in the folder with the image.
Some of the software is free. It is provided by the manufacture of the hardware. When the hardware is upgraded by the manufacture sometimes the old software becomes obsolete. Over a period of time the old software is no longer supported. Since the software was free they have no obligation to support it.
Now it becomes the OEM job to try to support it. The high cost is this service.
If it's licenced software that was issued for the equipment then to store back up copies for future repairs is not a problem. It's being used on the same piece of equipment.
04/28/2011 10:17 PM
Sir Ozzb,
Thank you very much for your comments & I am very glade & want to thank on your appreciable guide line. Ok i will do it as you said. please remember me in your prayers.
Register to Reply 6 comments
ahmadarshad (2); Garthh (1); ozzb (2); tooz (1)
